Erikson2k
An update was pushed today, media keys work now!
After being annoyed by your triple message posting I thought I’d check it out. You know “wanna” isn’t a real word, don’t you? Why would I pay for this when Soundiiz does the same for free?Try this and this would be a great help for you!
It Really worked. You can get it here.
https://musconv.com/
so what if you connect headphones directly to macbook? still mqa quality? does it sound good?yes.
Apple MacBook Pro 2016 --> Tidal Desktop Masters --> Meridian Explorer2 --> Moon Neo 430 --> Focal Utopia
what's most amazing is that..... take everything above but it's just Tidal lossless straight to the Moon Neo DAC/AMP... there are STILL things i hear with the Tidal Masters running thru the Meridian that i didn't hear before! same album, the MQA is the only difference.
amazing.
You know you look like a complete douche balloon being pedantic about grammar when **** like "wanna" and "gonna" are perfectly acceptable casual words, don't you?
Signed, just a jackass with an English degree
Except “wanna” is the first word in giant type on this spammer’s commercial website. You don’t see that often, do you?
As for your insult, it probably means more to you than it does to me.
Signed, just a jackass who has spent an entire career as a writer and editor.
You’re entitled to your opinion. You’re not, however, entitled to hurl insults. What you’re probably gonna wanna do at this point is can it. You’re not worth any further effort from me.Of course you would, if you're trying to come across as casual and informal. But I mean, if you're one of those snobby pedants who throws an absolute hissy fit at colloquialisms I'm sure seeing something as egregious as "wanna" would send you into hysterics.
I refer to my previous comment, redouble it, and add you to my ever-growing ignore list before I say something that will get me in trouble again.
Your username sure is appropriate, though.
I ran into a new bug today in my Tidal desktop app for Windows 10.
My computer music system is a Windows 10 machine connected to an Oppo HA-2 DAC which in turn is connected to a pair of Audioengine 5s. My Tidal streaming settings are Master Quality/Oppo driver/Exclusive Mode/Force Volume. In the past this has resulted in Tidal resetting my Oppo driver volume to 100% each time I start up Tidal. I don't want it that high, so I turn it down to about 25%. Annoying but manageable.
But as of today, Tidal resets the Oppo driver volume to 100% after every track. Not manageable.
Note - I don't see this behavior when I use other sources for my music (e.g. JRiver).
I can see several workarounds. One that I don't think will work is to rely on the volume control of the AE5s. At very low settings (which is where I would be with the Oppo at 100%) the balance of the AE5s is off. Deselecting Force Volume causes the metering to go crazy, and the SQ seems to suffer.
Thoughts? Fellow sufferers (with the Oppo or otherwise)?
Edit - probably the simplest workaround is to use the headphone cable for the AE5s and rely on the volume control on the HA-2.
What happens if you uncheck Force Volume in Tidal settings?
My understanding is that when you check Force Volume you are bypassing the volume control in the your PC sound card and sending the full bit stream to your DAC.
I don't think that is correct. When you check Use Exclusive Mode, the Tidal application bypasses the PC sound card sending its output directly to the device selected. Since the volume control is a function of the sound card, it is removed from the Exclusive Mode path. If you look at the right side of the Tidal player controls there is a small speaker icon that is a volume control for the Tidal player. When you check the Force volume it sets the player volume to 100% and grays out that speaker icon so you can not adjust it.
