SomeGuyDude
- Jun 24, 2012
I noted this morning that Tidal often includes CD Quality and MQA versions of the same album. So I spent a few minutes this morning doing comparisons (Toshiba laptop -> Oppo HA-2 with bass boost on -> AKG 701). To my surprise I was consistently able to hear a difference. I listened to about half a dozen albums - Modern Jazz Quartet, Joni Mitchell and Crosby Stills and Nash, all from the analog era. In the case of MJQ's "Blues on Bach" I also compared it with my ripped ALAC copy, but switching between versions on Tidal was faster, making comparison easier. I try to avoid hyperbole, so I won't say the difference was drastic, but it was significant in the sense that it changed my appreciation of the music. It was more significant than the difference between the SACD vs. redbook layers of many of the hybrid discs I have compared over the years.
As I said, I was quite surprised by this result. I don't consider myself to have golden ears (and I'm 65). Did the albums I tested derive from different source tapes? Was it the higher resolution of MQA or some other aspect of the process? Were there minor variations in the volume level? (In one case the volume level on the MQA version was substantially lower than the redbook, but I still preferred the MQA. I don't know, but I do know that the instruments on the MQA versions had more apparent color and in some cases more detail.
20 minutes of flipping back and forth is not the same as extended close listening, so I will continue to explore this.
It's a fairly good bet that MQAs are coming from a different source, but not only that the only way to really do a comparison would be if someone else was using the computer and swapped between the two and had you try to guess which was which.
Considering there has never been any successful test showing people can tell 320 from lossless, the idea that you can tell FLAC from MQA is incredibly suspect.
