Ok i can see why they choose Oracle now
ThieAudio Signature Series Tribrid IEMs
- Thread starter IEMusic
igor0203
soundblast75
- Nov 30, 2012
Available on Amazon??
Yes, it is, but doesn't come up on Google.
It's more expensive than getting direct from them and it says 2,3 weeks too, yeah
ngd3
- Apr 8, 2017
Gave the Hiby 20ohm impedance adapter with Monarch another shot with a DAP that I hadn't used in a while, the Ibasso DX228 EX version. Way better than using with the Sony ZX507 or Paw S1, so for those that tried it and didn't like the combo maybe try using a brighter source with more power. These might just about settle me for a long while on gear. Works well for low volume listening, then turning it up for when the track calls for some thunder bass. Too bad the DAP battery life is trash
Nathanial
Yeah I think they're including potential customs and VAT fees for their Amazon prices. It didn't say 2-3 weeks a couple of days ago when I checked so there's definitely been a spike in orders!Available on Amazon??
igor0203
Yes, they're both on German Amazon while Monarch and Clairvoyance aren't available.
I rather paid a little more and get it on Amazon in case something goes wrong
IIFC, the Oracle and Clairvoyance have similar frequency response curves. But, the Monarch and the Excalibur were quite a bit different with the Monarch as a bass boosted neutral and the Excalibur being more v-shaped. Did I remember that right? If so, then it's much less likely that there is overlap in the Monarch and Excalibur.
Since I already own the Monarch, I might pick up the Oracle to see how complementary they are. I really love the Monarch's tuning. So, I am not sure if I will see the tuning as an upgrade. The price is good enough were I might do it anyway. It might be a cheaper way to get something similar to the original twins.
soundblast75
- Nov 30, 2012
Yes, i have done both Amazon and Linsoul Direct, both very slow, but it arrives fine at the end. On Amazon, you can return it to China and you get all money back on Linsoul you're likely to get less because of conversion ratesYes, they're both on German Amazon while Monarch and Clairvoyance aren't available.
igor0203
My last purchase directly from them came in 2 weeks. I call that pretty good considering for some items from Ali, I waited 2-3 months.Yes, i have done both Amazon and Linsoul Direct, both very slow, but it arrives fine at the end. On Amazon, you can return it to China and you get all money back on Linsoul you're likely to get less because of conversion rates
I'll be using the Astell & Kern SR25. How does the DX228 stack up with that?Gave the Hiby 20ohm impedance adapter with Monarch another shot with a DAP that I hadn't used in a while, the Ibasso DX228 EX version. Way better than using with the Sony ZX507 or Paw S1, so for those that tried it and didn't like the combo maybe try using a brighter source with more power. These might just about settle me for a long while on gear. Works well for low volume listening, then turning it up for when the track calls for some thunder bass. Too bad the DAP battery life is trash
soundblast75
- Nov 30, 2012
Fair pointMy last purchase directly from them came in 2 weeks. I call that pretty good considering for some items from Ali, I waited 2-3 months.
Nathanial
I can second this. I had the same experience ordering to the UK through Amazon and directly through Linsoul. Just over two weeks in both cases, and one was over the holidays!My last purchase directly from them came in 2 weeks. I call that pretty good considering for some items from Ali, I waited 2-3 months.
Having the Oracle right now, and having owned the Monarch...I think the Oracle would be a great companion. The two sound completely different and both have the strengths that the reviewers have mentioned. I was looking for something that went well with a lot of the rock/indie music I listen to and the mids sound wonderful.IIFC, the Oracle and Clairvoyance have similar frequency response curves. But, the Monarch and the Excalibur were quite a bit different with the Monarch as a bass boosted neutral and the Excalibur being more v-shaped. Did I remember that right? If so, then it's much less likely that there is overlap in the Monarch and Excalibur.
Is the shell the same size? I had the Monarch, but it was a little too big for my ears.Having the Oracle right now, and having owned the Monarch...I think the Oracle would be a great companion. The two sound completely different and both have the strengths that the reviewers have mentioned. I was looking for something that went well with a lot of the rock/indie music I listen to and the mids sound wonderful.
I'm pretty sure they are smaller. The Monarchs felt a little big in my ears but the Oracle is super comfortable and I don't remember that being the case with the Monarch.Is the shell the same size? I had the Monarch, but it was a little too big for my ears.
