imacaverage
after a month of alternating use of the monarch 2 and ie600, the sennheisers forced out the monarchs, in ie600 the timbre is still perceived more naturally
This is what the audiophile community is demanding and the companies are responding to that. $3-4K IEMs are being sold like candies even when their differences are very slight. I don't understand the mentality. If you have a base tuning you like and you are happy with everything else (sensitivity, fit etc.), just use EQ to tweak small things and you are done. Especially considering the production / mixing differences between the recordings.Alarming trend of releasing new MK almost every year, Dunu SA6 OG, SA6 Ultra, SA6 MK2, Monarch MK1, MK2, MK3, Moondrop Blessing 1, 2, 3, etc.
HD650 lasted for how long before Sennheiser decided to introduce inferior to original HD660, still keeps original in production and sells at a hefty premium.
Especially w/ the excessive peak at 9-10k!? IE600 are close to masterpiece to me but still not so that close like MMk2.after a month of alternating use of the monarch 2 and ie600, the sennheisers forced out the monarchs, in ie600 the timbre is still perceived more naturally
The Monarch Mk2 is better than both Mests. Ive tested Mest OG and it was a disaster when it comes to the tuning. Ive had the Mest 2 and sold it after 2 weeks. The tuning of it was off, with its muffled and into my face vocals, too bright 6-8k area and a messed up imaging. When A/B the Monarch 2 vs Mest 2 i really regreted buying the Mests even for 980e new. Sold them for the u12t which are superior in every department.I really don't understand the hype about the Monarch mk2. They are not pretty, they are too big to fit comfortably in the ears. SQ is good for their price but it is definitely better to add some $$$ to Mest OG or mk2
with foam ear pads - everything is fineEspecially w/ the excessive peak at 9-10k!? IE600 are close to masterpiece to me but still not so that close like MMk2.
HP manufacturers are not artists and often even far from being competent in tuning headphone. Sometimes even the most experienced ones fail in a particular situation. For example, HifiMan is one of the two of my favorite brands in the market that can tune their "open back" HPs pretty well. I love their open back HPs. But they badly failed to bring their tuning into their closed back HPs, even with the latest Audivina. There is nothing artistic behind it, they just failed. Raal, for example openly admits that they couldn't tune it, or "preferred other features over a proper tuning". They advertise on some filters (a form of EQ) on their website for proper tuning them via software. So I would suggest not putting them in an artist category. They are people trying to sell some products, that is it.I do not see benefits of EQ for myself, only associated disadvantages as find much more pleasure in appreciating different headphones flavors.
My position that they should sound as creator intended, just like you don't mess with the original painting of the artist by adding your own touches to it.
Add to that loss of bitperfect output, no universally agreed upon target, difference between individual units to tune the same, distortion , etc.
In the end it's all just another "therapy", same as fancy cables.
Sometimes EQ software reduces the replay gain if you engage it in order to avoid clipping, which is most probably what you are hearing. It is just a reduction in volume. If you are using Android DAP, I can recommend Poweramp Player or the standalone Poweramp EQ which can do system level equalisation (can also EQ external applications like Qobuz, but needs Android 10+, I think).This could be a function of not using or finding the right app for EQ... but when I apply any EQ at all I feel like a hear a drop in sound quality across the entire FR. Like, it gets a little muffled. So generally I just don't use it.
Thanks, had no idea. Proving my point, Prestige, Prestige LTD, just another unnecessary revision to suck money out of the consumer.You don't want the original Prestige if you want to go Prestige way, the LTD version is for you.
It's hard not to hear the difference between exclusive bit-perfect WASAPI or ASIO and Shared mode required by Equalizer APO on PC.About "loss of bit perfection" is another exaggerated point. I am not working in the audio field but DSP programming is what pays my bills and buys my "toys" at the moment, so as long as the implementation was done by someone that knows what he is doing, there is absolutely no way for someone to hear the a worse sound due to not being bitperfect.
I think, with the LTD version they wanted to prove that their actual flagship is worth saving from fail, thats why they improved the trebles from the OG version. I havent heard either of them but the LTD version looks promising to me.Thanks, had no idea. Proving my point, Prestige, Prestige LTD, just another unnecessary revision to suck money out of the consumer.
Which tips were you using before?I'm with you. I much prefer MEST to Monarch MKII, and I also prefer the OG Monarch to the MKII as well. Both have more "special sauce" to my ears whereas MKII is kinda boring and uninspired to me(even though I still recognize its strengths). Although I'm appreciating the MKII more than ever with these Pentaconn Brass tips. Adds more thump to the bass and a little more air to the signature. I feel like I've unlocked the MKII or something.
