AudioDwebe
- May 1, 2006
So I'm gonna have to remove the bottom and look for what sounds like a loose screw or something inside the amp. I went to move it from my desk this morning and, when I tilted the amp, I heard the little something in there roll along the bottom. I tilted it the other way, and it rolled that way.
Sheesh...
As for "blowing up", I think this amp is safe, as the following tests were performed by a tech: Installed 220K bleeder resisters throughout power supply; tested tubes; verified stability of capacitors and power resistors; performed signal and voltage tests. They also cleaned all controls, switches, jacks and sockets; set/checked bias and bench tested.
To be continued...
Sheesh...
To be continued...
