Mine doesn't ! I really, really wish it did. Are you using 2.09 firmware ? I only ever use folder view and would love it to keep playing after an album finishes, like my old Fiios used to.
I'd like to be able to delete files too, but that's a bit harder I guess.
@Ravinder, are you at the latest firmware? (I know it has to come back to life 1st). Get there. The later firmware are worlds better than what mine came with. Anything can sit I stock for years until someone buys it, coming with an old firmware.
I did not even get the chance to update its firmware and put mSd card in it. It was switched on twice for 10-15 minutes each before it went dead. Anyway it happened within seven days and has been sent back for replacement.
Will do the same as soon as I get the replacement.
I have never found a play through folder option. I wish it did have that. I do have the option on my Cayin N3 and my Hidizs AP200. My little Ruizu A50 does it automatically. Sometimes I wish I had the option to disable it.
I often use artist view because I have no idea which artists are on which card. If only I had just done it alphabetically. I have to use folder view for various artists albums or classical because otherwise it is a mess.
Then I dont understand what "play thru folders" means. I take is as...
- click the three stacked lines on the top left
- click Folders
- click the < back arrow at the top left.
- click thru to where I want to play from ... one album or at a higher directory level with a few to many folders
- click the right arrow surrounded by a circle.
- folder(s) play.
If not that, what is it?
Edit: so does it mean you select one folder to play, it ends, and goes into the next in the dir structure? If so, okay.
Well, I categorize everything in a music root, then the rip format (Redbook, live from archive.org, HDTracks, etc.], then genre folders, then artist folders, then albums. Can play from any of those levels. Playing the folders if you start anywhere but an album, say at the artist or genre level.
It means while playing in folder mode, when it finishes playing the last song in a folder it automatically starts playing the first song in the next folder.
- click Folders
- folder(s) play.
Starting to get to the bottom of this now ! Thanks to m8o for steering me in the right direction.
If you navigate (as m8o said) to the folders view, and click on the play button with the two-arrowed ring around it to the right of the folder you want to play, it will play everything in that folder AND its subfolders . I just had a quick test and if I click on (for example) my Porcupine Tree folder. it starts to play the first track of the first folder, and shows that I am playing track 1 of 167. (I'm a big fan). It is 'kind-of' playing through folders, but not as intuitive as just doing it universally. You don't seem to be able to start from anywhere but the first track. Slightly better than not having it at all - in my view anyway !
I can see that method does work for me as well. I was looking for more of a universal play through folders - the artist to artist kind. But, thanks for that tip.
I have mp3 files (C,S,N&Y 1974-a live in-concert album) that play through perfectly in iTunes. However, on my #1Metal Premium each track is separated by a short gap. Gapless is turned ON in settings. Other FLAC files of gapless albums (ex: Abbey Road, side 2) play through gapless. Any suggestions or information would be appreciated.
Note: The tracks in question were converted from 16/44 FLAC to mp3 (Lame) using dB Batch Converter.
(The FLAC files also play gapless in foobar2000)
Those mp3 files play gapless in foobar2000. I was trying to save space on my ext. micro sd card, so I created an iTunes folder on internal storage filled with music I enjoy, but don't listen to critically. This particular album falls into that category, for me. ( I have other CSNY - group & individuals - albums as FLACs, though.)
Just got a used Opus one and am extremely pleased with the sound quality, miles ahead of the dx80. Everything is great except that the unit does not appear to read .cue sheets...? Really? I've tried searching for a solution in this thread and the broader internets without any luck. I am running what I believe is the latest firmware, I don't have it in front of me but something like 2.00.09. Is there a workaround for this? Seems crazy that such a foundational element of usability would have been either overlooked or omitted. Thanks for any help
It's *possible* MusicTeck (in the US) may have them available: https://shop.musicteck.com. Also try searching Mitre cases on ebay for them, I believe they supplied the case for the Opus#1.
