slavalun
Is TPA6120A2 any good?
Prefers high-resistance load (from 60 Ohm), with decreasing resistance, harmonic distortion increases
It's depends of your pocketMy idea for what I want to do with my Zishan. To have the 18650 cells on the sides so that it is pocketable. What do you think?
@moshe tes
There's also the option of this battery with same size, but double the thickness and double the capacity of the original. It gives 6000mAh for 9.6mm thickness. I never tried it.
https://www.aliexpress.com/item/33011185788.html
https://www.aliexpress.com/item/32795911992.html
The internal battery could be removed, giving additional ~5mm inside space for bigger cap mods and the new 9.6mm battery could be mounted outside the original case back.
Then a lid could be cut from another same size generic case bought in AliExp and just put over the back.
The back lid would be cut in the new case like this photo:
https://www.head-fi.org/threads/the-zishan-dsds-corner.826185/page-109#post-14749153
If you don't need the 5mm internal space just put the new batt inside and add only 5mm thickness to the original case.
Oh I have the Z3 AK4493 version that has only a few mods. Changed the LPF opamp to OPA1612 and headphone driver to OPA1622. It is definitely more detailed, but still not as detailed as it could be and not as impactful as I'd like it to be. I still need to figure out the circuitry on it. I followed some of your advice on the Z3 forum but not enough information. I am still not sure how it gets +-13V.Maybe this will interest some:
https://www.head-fi.org/threads/zishan-z3-hi-fi-player-thread.911846/page-3#post-15977278
New Z3 "version on Ali and Tao with Cirrus Logic cs43198".
Why is there continuity between the left and right channels near the 3.5mm output jack of the Zishan DSD. Is that normal? I thought they were supposed to be separate. There seems to be continuity between both channels and also between both channels and ground. I am confused. Also could you please explain the interaction between the relay and the 3.5mm jack? Does the output from the buffer go to the relay? If so, is it both Left and Right or Ground or all? I imagine the FET near the relay is used to switch the relay?
When USB mode is on, the EQ is overridden by your pc custom settings, for digital filter implemented on DAC still there due to HW/SW implementation of i2c in RTOS.hi
in usb dac mode, filters of dac works ?thanks in advance
I had crashing back when I bought Z1, Z2, DSD, only thing that solved it for me was deleting all music files metadata (used some software for that), sometimes metadata with song info fields or image is corrupted or too big and the fw doesn't account for that. I think I even had to delete 1 or 2 music files, because zishan would always crash on them.
After this was done, I didn't had any crash ever again in any of them.
