The Zishan dsd's corner
Jun 4, 2020 at 8:54 AM Post #2,761 of 3,717
Firmware 0.5 not possible to install at 4495
But nothing bad happens. The firmware simply does not install.
Jun 4, 2020 at 9:32 AM Post #2,763 of 3,717
if it works, why you return?
I just checked the options right away to make it clear to everyone. I have 4495, 4497 and 4499 =)
It is not always possible to install earlier firmware on player.
Jun 4, 2020 at 9:38 AM Post #2,764 of 3,717
I checked on my old 4497 - everything works. I also returned firmware 0.4H - no problem.
Thanks, I will give it a try later. Any improvements? I noticed on the last version, my dsd runs a bit cooler.
Jun 4, 2020 at 10:03 AM Post #2,765 of 3,717
Jun 5, 2020 at 12:54 PM Post #2,767 of 3,717
How do I update the firmware after downloading?
After unRARing the downloaded file, Copy the extracted files to the root directory of a memory card (microsd on 4499), insert memory card and turn the Zishan on.
Jun 6, 2020 at 10:46 AM Post #2,769 of 3,717
Hi all,
firmwares version 0.5b
https://drive.nlmk.com/index.php/s/WL8fEgrXLfn3pxX
I've installed the 0.5b firmware on both my Single AK4497 and Dual AK4497 DSD units.
The interface & settings are the same on both, and the Dual AK4497 unit shows 0.5b on the screen - but the Single AK4497 unit still shows 0.4i.
Jun 6, 2020 at 4:15 PM Post #2,771 of 3,717
Same here with single ak4497, it shows it's flashing 0.5b, but after power on it still shows 0.4k that I had before.
Jun 7, 2020 at 3:57 AM Post #2,773 of 3,717
Mine (single 4497) just keeps reflashing in a loop.
You may need to take the memory card out and delete the update files so it won't flash them again.
Jun 7, 2020 at 10:22 AM Post #2,774 of 3,717
I was able to update my single 4497 to 0.4k, but it still won't update to 0.5b - even after rebooting, and attempting to re-flash several times.
Jun 7, 2020 at 12:10 PM Post #2,775 of 3,717
Single AK4497:
