Merlin-PT
- Jan 21, 2005
The audio path is this:
DAC - 4x 100uF - 2x opa275 - 2.5mm output
So when you change these, listen to the 2.5mm output.
DAC - 4x 100uF - 2x opa275 - 1xLM4562 - discrete transistors - 2x 220uF - 3.5mm output
First part are the same components from before, but it also goes to the socket opamp before the 2.5mm output.
So all the caps and all opamps affect 3.5mm output, but only the 2x opa275 and the 4x100uF affect the 2.5mm output, so tune 2.5mm output to your liking first.
You can use higher voltage without a problem.
I use the expression audio path to differentiate these caps from the power supply reserve and filtering caps.
