Well, obviously, it would take years of experience to have enough skill to discern those tiny nuances, so there
would be a degree of subjectivity in it too. But, the reason why I call it an ideal, objective
reference is because we're not taking into account any biases or preferences the end user may have here. We're using the IEM as control, and we're letting
only the tracks be the variables. Unfortunately, it's impossible to establish a singular baseline with a single listen or a single measurement. It's not like a desktop monitor where we can slap a measuring device and see how color accurate it is or how much contrast it has. The only way is to listen to a bunch of tracks and see how distinct the IEM can make each track sound. In the Tom Misch example, we can objectively say there is a difference in the way his vocals sound between tracks 2 and 3 because, well, there
is a difference. We're not introducing any subjectivity by saying which of the two sounds
better, or
more correct, etc., but there definitely is
a difference. You can hear it on a number of earphones that err on
neutral. The one that showcases that distinction best would be the most
reference-ish of them all... but only in that region, specifically.
Obviously, just using that test is barely enough to call an IEM's midrange
reference, let alone the sum of its parts. That's why we need a wide variety of tracks for the IEM to output, so we can see what qualities stay and what qualities don't. To reuse the U18t as an example, if I listen to 10 tracks with the IEM, I'll hear the same 7kHz
tizz on every single one. It's a quality that stays, adds a common tint to every track I listen to and, therefore, minimizes the differences between them. So, it isn't an ideal
reference. There are a number of
bass cannon in-ears that give a similar
oomph down low to every track it plays, and we've established that
similar and
reference don't mix. This applies also to texture, imaging, dynamics, etc. If we take a desktop monitor again as an example, if you put up 10 different images (from 10 different artists and 10 different mediums) and they all have a slight green tint, it wouldn't be unreasonable to say the green tint is a coloration of the monitor, no? The display that makes those 10 images as distinct as possible would then be the ideal, objective
reference.
So, the difference between the objective
reference and subjective
reference is that the former may not sound "comfortable" to you. It's not designed to sound
correct to you, necessarily. Its main purpose is to be as transparent as possible by showcasing as many differences between tracks as possible, and that may mean certain tracks sounding
off or unnatural. More likely than not, that's just how the track was mixed and mastered in the first place. And, that is where the last line of your reply comes in. That ultimate, objective
reference will
not be for everyone. I think marketing for headphones and earphones has been incredibly detrimental in making people think this sound is what every audiophile should be striving for.
Listen to the tracks as the artists intended! Purely colorless and transparent! In my opinion, that's all BS. I say, find the IEM that sounds best and most correct
to you. Heck, do I listen to the A18s when I'm not working nowadays? No. It's the JH Sharona if I still want that
reference-ish sound, the Nightjar Acoustics Singularity for fun, or my car speakers the other 90% of the time. As I've said numerous times in the past, the
reference sound isn't the
best or
ultimate sound. It's just
a sound.
Yeah, exactly. I've heard the Harman curve a few times, and the word that keeps coming back to me is "digestible." It's safe, unexaggerated and blasé. The issue I run into most with it, as it's most commonly found in cheaper IEMs, is it has nowhere near the technical faculties to be comfortably called
reference. Most of the times I've run into the Harman curve are on IEMs with compressed dynamics, same-y imaging, etc. I think that's the bit most people forget when they're trying to pin down whether or not an IEM is reference.
I talked about my definitions of
neutral and
natural some time ago. I feel
neutral is like that ideal
reference I talked about. It's the sound that doesn't necessarily come natural to you, but shows off the differences between tracks most clearly, and, therefore, is colorless. Because it's used in tonal connotations more often than not, I think
neutral can be summarized as
objective reference, but without the technicalities part (dynamics, imaging, etc) playing as big of a role. As I explained above, because we can't pin down an exact
reference or
neutral sound based on one listen (as it would be far too subjective), the only way to determine that would be listen to as many tracks as possible and see which IEM makes them sound as distinct as possible. That's been my longstanding opinion for years now, and I'm still looking for that one thing that'll change my mind.
