During Canjam Day 2, I revisited some IEMs that I liked.
Subtonic Storm
First day: The fit was great, one of the better ones for me during the show. I also liked the deep recessed female 2 pin slots on the shell. This is one of the things I grew to appreciate on the Traillii shell as well. Sonics: I didnt like the way the stock combo sounded with SP3K. Both Storm and SP3K are conservatively tuned. This made it sound even more flat. After using various tips to get a deeper insertion, it lifted some of that veil as well as getting a better sub bass response. I liked it more with @Chang Fiio Q7. It sounded cleaner.
Storm is a highly resolving reference tuned set. This is one of the best BA bass I have heard. It's also the type of sound that is a sleeper hit. It got better the longer I listened. Unlike XE6 or Radon 6 that makes a statement right away, Storm is reserved in that respect. Every now and then I would recall what I heard and realize how much detail was reveiled in a track. The staging I found was on the smaller more intimate side (both height and width) compared to Mentor or XE6. The height especially seemed shorter. It reminded me of Turii Tis stage. I was a fan of the bass and the transition to the mids. A problem I ran into was the highs. During calm vocal tracks, I was getting peaks. An example was during the S" on "The House of the Rising Sun".
I replaced the Mira 4 with PW Orpheus and it cut that energy down.
Orphy injected some warmth. Staging got more expansive, vocals sounded richer and it took the resolution up another notch.
Second day: I tried the same combo and confirmed my first day findings.
Noble Viking
This is @wazzupi full damascus version. Definitely one of the best looking iems I have seen next to Indigo. I like that the damascus pattern extends throughout the whole shell. The embedded Noble logo on the faceplate gives it a regal, elegant appearance. This has the same tuning as the Ragnar. It paired quite well with SP3K which smoothed out some of the treble for me. Similar to Storm I liked it even more with the Orpheus.
The fit was decent similar to the Viking Ragnar.
This combo was quite epic. Huge enveloping staging and instruments were well separated, great resolution. The SP3K and Orphy however didnt reduce enough of the treble to make it viable for me to use for EDM. It sounded fantastic for classical. This is one the most resolving sets out there. The recently released Noble Ronin goes for a different tuning. Its musical up Mentor / Traillii alley.
Noble Ronin Vs Mentor
Fit: Ronin 6/10 (large), Mentor 8.5/10
I used Phantom of The Opera to test timbre, Armin Van Buuren to test electronic, technicalities and dynamics with Tchaikovskys Valse Sentimale.
After hearing the Ronin both days and AB testing it against the Mentor I found that it is competes with technicalities. Ronin in some ways reminds me of the Traillii (also running BA EST config). It has great vocals, but better bass. I also found the highs to extend more. Between Mentor and Ronin I found it quite close. These are both great.
Female vocals: Ronin
Male vocals: Mentor
Bass: Ronin
Mids: Ronin
Treble: Mentor
Acoustic Timbre: Ronin
Electronic: Mentor
These can both do vocals well. I found Ronin to have better balanced timbre for female vocals. With Mentor depending on the track the mid treble pushes the S' of vocals where the Ronin was smoother. Ronin would be my choice for vocals / classical / Jazz and Mentor would be my choice for electronic, rock, metalcore. Ronin sounds fuller, warmer slightly relaxed highs, Mentor has next level imaging and more extended highs.
Jomo Alpha Ti vs Mentor
Fit: Alpha Ti 9/10, Mentor 8.5/10. The jomo is also quite light.
These are quite different tunings. The Alpha Ti has a smoother more analog tonality. I would equate its resolution near XE6 but without the treble sparkle. In comparison the highs seems rolled off. Mentor goes for a vivid, more immersive presentation with more air to strings and sparkle with the xylephone. Alpha TI has satisfying DD bass. I found it to sound best with slow music. Alpha ti slams more while Mentor had more resolution. Alpha tis stage height and depth was smaller compared to Mentor. My choice in most categories was Mentor.
Xe6 vs Radon 6
Fit: Both 9/10 while RN6 was lighter.
These are both amazing iems. The RN6 shell reminds of a minature Elysian X shell with the gold flakes on the faceplate. I believe this is a 5 year limited edition and it will not be coming out with a custom.
I compared the two using silver modules and the same tips (Deep Mount Radius). Radnon 6 to me sounds like a restrained XE6. There is a bit more sub bass, mid bass reduction (around 20%). Radon 6 still felt like a warm IEM overall. XE6 had more slam, more powerful macro dynamics while the Radon 6 sounded more linear. While I liked Radon 6, I didnt feel the tuning changes warrants owning both. A KR5 would be more complimentary for me if I were to own another Fir.
Subtonic Storm
Noble Viking
Male vocals: Mentor
Bass: Ronin
Mids: Ronin
Treble: Mentor
Electronic: Mentor
Xe6 vs Radon 6
