Zombie_X
Anybody have any cheap headphones they no longer want? I'll take em and slap a balanced plug on em for this test.
Originally Posted by TheKisho /img/forum/go_quote.gif All I can think is to use the ALPs 4 channel volume control but that's a little big to cram into a portable device but it can be done, not sure how cheap that pot was last time I checked. Dual two channel controlled by motor probably isn't possible at that size. Haha I once seen a quadraphonic amplifier with dual stereo pots and gearing to control both as one, or one at a time. Could try gearing ;P It can be done. Best bet is cram the 4 channel ALPs pot in there sideways and fill the remaining space with the amp. The case limitations would be the width/height of the pot (the case can't be any thinner then that). |
Originally Posted by Zombie_X Anybody have any cheap headphones they no longer want? I'll take em and slap a balanced plug on em for this test |
Originally Posted by MrGreen /img/forum/go_quote.gif Can anyone give me a scientific reason why bass would "tighten" from changing termination type? |
Originally Posted by progo /img/forum/go_quote.gif It's not the plug, but the balanced amplification (and audio chain in general) that has a few benefits over single-ended gear. |
Originally Posted by MrGreen /img/forum/go_quote.gif Doesnt that result in +ve and -ve voltage swings (to make double the potential difference)? Surely a single-ended amplifier with twice the voltage swing would do something similar. And itll remove crosstalk from RFI because the ground is not active. |
Originally Posted by MrGreen /img/forum/go_quote.gif But how does that "tighten" bass? |
Originally Posted by MrGreen /img/forum/go_quote.gif Can anyone give me a scientific reason why bass would "tighten" from changing termination type? also regading those er4. What tips are they and how do they change the sound and how big are they compared to the triflange. |
Originally Posted by Zaubertuba /img/forum/go_quote.gif Wait a minute...if you're using a DAP with a volume control, then you don't even need a quad pot, just resistors of the right value on the input. A quarter of the cost of the pot (about $11) easily takes care of the single-ended-->double-ended conversion. Think about it: Sansa Clip....$35 Balanced (or "bridged") CMOY....$40 Balanced PortaPros...$35 A balanced setup you can easily take with you.....Priceless! |
Originally Posted by ting.mike /img/forum/go_quote.gif Zaubertuba, how does a resistor takes care of the single ended to double ended conversion? |
Originally Posted by Zaubertuba /img/forum/go_quote.gif Wait a minute...if you're using a DAP with a volume control, then you don't even need a quad pot, just resistors of the right value on the input. A quarter of the cost of the pot (about $11) easily takes care of the single-ended-->double-ended conversion. |
Originally Posted by ting.mike /img/forum/go_quote.gif Balanced CMOY is the easy part. What balanced source would you use? |
Originally Posted by TheKisho /img/forum/go_quote.gif Um I'm unfamiliar with a DAP (Digital Audio Processing? Digital Audio Potentiometer?). I'd probably still build the portable amp with a quad pot just for the heck of it, if I made one. |
You don't have to use a Balanced source. You could always make a unbalanced to balanced converter with some Op Amps. If you want to go balanced all the way, you could always make a balanced DAC while your at it. |
