The Official Sony TA-ZH1ES Hi-Res Headphone Amplifier (Live From IFA 2016)
Feb 25, 2021 at 3:41 AM Post #4,111 of 5,783
Why there are no reviews in Head Gear section?
Does this dac/amp suitable with sensitive Campfire Audio's IEMs?
Probably because nobody have ever made one.
No idea about how it works with CA iems but it works great with my IER-Z1R and JH13 though I primarily use it with MDR-Z1R
Feb 25, 2021 at 3:44 AM Post #4,112 of 5,783
CA IEM’s do not hiss at all with TA, however the output impedance is on the high side so you will lose a fair bit of bass quantity from the likes of Andromeda and/or Solaris.
Feb 25, 2021 at 3:47 AM Post #4,113 of 5,783
Thanks! But how does bass quantity connect with output impedance?
Feb 25, 2021 at 3:50 AM Post #4,114 of 5,783
There has to be a match between output impedance on the amp and the headphone. Especially on multi unit balanced armature in ears a high output impedance will skew the frequency response on the headphone
Mar 3, 2021 at 7:19 PM Post #4,115 of 5,783
Mar 5, 2021 at 4:36 PM Post #4,116 of 5,783
Hi all, im a frequent headfier, i just purchased a TA- Z1HES intending to use with my Z1R's. Firstly can i use my LG V60 into the micro usb/ walkman port?
Secondly i have all my FLAC files on a pc using Media Center 27. Which will be the best way to connect? (I use an ASUS Essence STX 2 soundcard)
Many thanks in advance
Mar 6, 2021 at 1:34 AM Post #4,117 of 5,783
Mar 6, 2021 at 4:10 AM Post #4,118 of 5,783
The Walkman input is just an USB micro B plug. I've tried connecting my Android phone to it and was able to play music over the TA-ZH1ES.
How were the results using your phone?
Im not clear as to do this or use the micro usb b on the rear. Any help will be much appreciated (i will purchase a single purpose cable depending on the best outcome)
Mar 6, 2021 at 10:21 AM Post #4,119 of 5,783
The USB-B on the back supports higher sample rates than the Walkman micro-USB on the side.
Mar 7, 2021 at 5:45 PM Post #4,120 of 5,783
Mar 7, 2021 at 6:17 PM Post #4,121 of 5,783
So the FPGA inside is EP4CE55U19I7N, which is one made by Intel.
Mar 8, 2021 at 3:41 PM Post #4,122 of 5,783
Mar 11, 2021 at 5:05 AM Post #4,124 of 5,783
What does anyone use to stop dust entering the mesh on the top ?
I will go crazy if i get any in there (and no i'm not ocd)😁
I keep a small cloth over it 100% of time when not in use.
Mar 11, 2021 at 5:16 AM Post #4,125 of 5,783
