Umwelt
Just use VLC. It plays everything cleanly and accurately, it's free, open source, and available for pretty much all operating systems.
After playing around with inputs it seems the pc doesn't recognize the dac anymore,when connected to it,both leds are on,any ideas?Not a bad idea at all
It's cool that galvanic isolators work with other USB stuff and don't discard boutique cables.
@morgenstern09 has. Didn't do much for him. He was trying to decrese the audio delay with his wm1a, as far as I remember.Has anyone played with these settings ? *setting i guess
Can you give more details?After playing around with inputs it seems the pc doesn't recognize the dac anymore,when connected to it,both leds are on,any ideas?
Switched a bit between usb inputs and optical cable while playing music to do a/b tests.Seems to have bugged out not only the Tidal app,but also Windows.Tried restarting and etc but still won't detect the TA when connected via the igalvanic.I know a lot of reviewers had problems when testing since you need to set it up a certain way.Read about it but don't remember.Worked fine in the start though until windows/tidal bugged out.@morgenstern09 has. Didn't do much for him. He was trying to decrese the audio delay with his wm1a, as far as I remember.
Does it detect it without the ifi?Switched a bit between usb inputs and optical cable while playing music to do a/b tests.Seems to have bugged out not only the Tidal app,but also Windows.Tried restarting and etc but still won't detect the TA when connected via the igalvanic.I know a lot of reviewers had problems when testing since you need to set it up a certain way.Read about it but don't remember.Worked fine in the start though until windows/tidal bugged out.
Sounds like the igalvanic is the one that got messed up.yes but device manager keeps refreshing every second when i connect the Igalvanic ,like in only detects it for a split second
And my list of connected usb devices gets filed with like 20 devices like it's spamming connections.yes but device manager keeps refreshing every second when i connect the Igalvanic ,like in only detects it for a split second
it worked for me for a few songs,was more of an improvement than the Jitterbug which i'm starting to doubt the effects of.I have tried iGalvanic with TA and it flat out does not work. Neither the iGalvanic or TA are malfunctioning but the combination is a no-go. I also don't expect iFi or Sony to figure out what the problem is.
Audirvana has the best features and sound to me.For those connecting their Mac (or PC) computers to the TA via USB B, What're you using for software? I'm trying out Amarre Luxe, and really like it. Just wish it wasn't $100 though.
