JoetheArachnid
- May 10, 2010
As I understand it, the E9 dock completely bypasses the E7's internal amp, ONLY using the DAC section. Since the EQ is implemented as part of the amp section, that gets bypassed too. Yeah it's a bit annoying, but since you've almost certainly got the E7+E9 combo plugged into a computer you probably have access to some kind of EQ on there which can be used instead. Perhaps FiiO could post the EQ curves they use for the bass boost? It's probably a trade secret...
There's also supposed to be a standard LOD cable (L7) for the E7 coming at some point to allow you to use it as a standalone DAC. Don't know when we'll see it, though.
I understand that logic. You're not getting the purest audio signal if you're able to tweak EQ somewhere in the audio chain. However, I assumed that when the E7 was docked, that the E7 and E9 works synonymously as one device, so I thought you were able to use the E7's EQ settings, and the E9's amping with no degradation of the source between both devices (as I thought they worked as one similar to the E7's DAC and AMP properties). I'm not knowledgeable as to how all this works, so forgive me for misunderstanding how all this works. They're both great products and I'm very pleased with what they both can do.I don't NEED the E7's EQ settings, but if I did, I wouldn't mind undocking it and using it in the way I posted, even at the cost of it not being a TRUE line out...![]()
![biggrin.gif](http://files.head-fi.org/images/smilies/biggrin.gif)
