nrbatista
- Mar 30, 2012
Nozzle is too long? Not the problem. Just find an o ring of your choice. Now you can tune the length to suit your eartips.
Where did you buy those o rings from?
Having owned both I’d say they’re very different - the noir feels more like a trio upgrade while the Fourte is its own thingWould you say the Tia Fourte Noir is completely different from the regular Tia Fourte? I tried the normal one and I wasn't a fan of it: somewhere the tonality was off compared to the U18t and U12t.
The Fourte’s tone is one of the weirdest things the audio industry has produced haha, it’s a bit of a love it or hate it. Personally I find it quite unique and interesting and do enjoy it for the occasional listening session but I wouldn’t pick it to be my only IEMThat's interesting, considering that I actually thought that the Trio was better than a Fourte. At least tone-wise.
I think 64 changing their U designs to accommodate for deeper insertion would be a good idea - their customs are some of the deeper insertion ones while the universals are on the much shallower end of the spectrum so the difference ends up being quite significant
Sacrifice the nozzle of one of the tips you aren't using is one way.Where did you buy those o rings from?
Will try that and report back!Sacrifice the nozzle of one of the tips you aren't using is one way.
I bought mine from Amazon, just make sure you measure your nozzle to get the right size.Where did you buy those o rings from?
That's the thing: I reckon the A12t's bass is already on the edge of too much, and the N8 takes it to another level!
Truly a basshead's dream IEM. I reckon it easily eclipses the Solaris on that front at least.
From memory, I wouldn't say there was more bass on the N8s compared to the A12t, but it "hits" different. I can't really explain it but from demo'ing around I've noticed I really only enjoy DD bass.
I have been thinking about the N8 or JHA Lola. I do have impressions on file at 64 Audio, but none at JH Audio. On the other hand, I demoed the Lola last year, but never heard the N8.
dd bass is usually more organic, with rounder initial impact and a slower, longer decay.
ba bass is generally faster, tighter, and trades organicity for detail.
