Is there a trick to getting Spinfits to stay in your ear? No matter what I do they start sliding out after about 10 seconds....
I have the same issue with Spinfits.
Hi, this was the case when I used to sell 64audio back in the day. At least in SEAHonestly, that is why it is always best to say in IMO or something similar to preface a statement such as the one you made. It is okay to not be in the know on something once in awhile.
Again, you spoke directly to 64 Audio about their sales of the Trio? It would be an assumption that it might be replaced with a newer model soon when you see the deep discount being offered. Have they verified to you that the Trio is at the end of the line for that model?
Really interesting.Yes. Tried medium then large. I would need glue they are so slippery.
They did sound decent, but not really better than the stock tips (although it’s a pita to audition when they don’t stay put).
Really interesting.
Curious question, do you leave on a wet weather region?
Regarding Sound, I didn't noticed much difference or I just enjoyed every single IEM with that tip. I noticed more sound difference when using foam tips or going from standard bore size tip to wide ones.
Our tastes differ with regard to bass, but I completely agree with you about the Trio's treble. Absolutely wonderful. I could listen to that delicacy and detail for four to six hours in a day easily. It's a whole different level from "sparkle".
I’m thinking of buying a Plussound Poetic cable to use with my Fourte (primary) and maybe U18t. Is there good advice on which wire material conducts best for those IEMs?
i like the look of the Poetic, it looks reasonably ergonomic and soft too?
Come on 64audio
RHA also makes dual flange tips.
I wish Spin Fit would make a wide-bore CP240. CP240W? Leave the part that slips over the sound pipe the same (3mm?), but make the bore 4mm or so. I think that would open up the sound. Especially with fat IEMs like Campfire Audio.
Great info. Will give them a try when I get the chance.
+1 on this. I tried the CP220 as well which has very slightly wider bore but shorter than CP240. The sound opened up noticeably but for some reason the very top end (may be 9-10k or above) was lost. Could be my ear canal problem again though...
I don't think I've seen a CP220, where did you get them?
I've been a cable sceptic all my life, until I got a pair of U12t and started playing around with different cables. Currently using a Forza Audioworks Hybrid, and the jump in vocal clarity and air compared to a pure copper cable is remarkable. I wouldn't have believed it if I hadn't heard it for myself. And that's with LiD... Personally I think LiD is brilliant, especially if you're using multiple (sometimes very powerful) DAPs, and mix/matching between daps, phones and desktop amps. Definitely worth the hit (if any) it makes to extreme cable rolling.Cable rolling really made a big difference in sound signature with a LID-less A12tr
