Trios are here... These are a whole new beast. The lid tech works so well I was shocked how good they sounded out of my s9. Totl detail and 3d stage in such a small convenient package, now I just need a good dap. At first they sounded a bit off but they really get in your head, and out of it. Using ML JVC spiral dots and very happy
The Official 64 Audio Thread | apex & tia Technologies
jmpsmash
picked up a used U18t. hopefully they will be an upgrade from the Andromeda. Will find out hopefully this weekend.
I don’t think you’ll be disappointed
TonySunshine
- Jan 2, 2005
got the dignis arca case for my N8's today. The stock 64 audio case is awesome and well thought out, but doesn't really have space for anything else. The Arca has just enough space for the N8s, Earstudio ES100, ifi IEmatch, and 2 adapters.
Was stinking expensive for what it is, but I haven't found anything equivalent cases. Didn't want a huge and heavy pelican case, and those don't have any organization features.
GiullianSN
Nice arrangement, I carry a BTR3 and a short adapter cable. but quick question, does the ifi iMatch makes any difference with the N8? I would expect the 64a LID technology to do that job.
TonySunshine
- Jan 2, 2005
I primarily use the ifi IEmatch when I use the n8 with the e1da powerdac v2. The iematch serves as a pad to keep the powerdac from blowing up my ears/the n8s.
My understanding is that output impedance of a source affects the low end, and discriminates with balanced armature drivers? So I think since the n8 has a dynamic driver for the subwoofer, LID doesnt do a whole lot?
KuroKitsu
Doing a swap of the VX for u12t in a couple weeks. I want to reuse the cable I had built with reverse polarity because QDC for some weird reason does that as a thing.
Does the polarity really matter for an iem?
kendosperling
Just change both 2-pins and there will be no problem. If the polarity of only one iem is changed you will notice t very fast. You may test it at this site https://www.audiocheck.net/soundtests_headphones.php at chapter wiringDoing a swap of the VX for u12t in a couple weeks. I want to reuse the cable I had built with reverse polarity because QDC for some weird reason does that as a thing.
mvvRAZ
I'm really glad to hear that, I am placing an order for my father's birthday (he will be using them with his iPhone, no way he carries a DAP around), and I think the trio is hands down the best IEM you can get if you aren't looking to massively upgrade the rest of your setup, more so than a phone or whateverTrios are here... These are a whole new beast. The lid tech works so well I was shocked how good they sounded out of my s9. Totl detail and 3d stage in such a small convenient package, now I just need a good dap. At first they sounded a bit off but they really get in your head, and out of it. Using ML JVC spiral dots and very happy
just received my a12t and love it... i was finding back in black by ac/dc sounding very thin on everything i had, and i thought it was a bad recording... nah i just had poor gear... loving the a12t... a lot of money though
toaster
u12/a12t don't know the meaning of the word, "thin."
enjoy, man.
enjoy, man.
KuroKitsu
Its going to cost me about $70 usd to get it redone by Triton (and mailing time). So I'd want to avoid.Just change both 2-pins and there will be no problem. If the polarity of only one iem is changed you will notice t very fast. You may test it at this site https://www.audiocheck.net/soundtests_headphones.php at chapter wiring
I already did the polarity tests with both cables off my A6t. No issues at all, regardless of whether of whether each cable was regular or reversed.
Hoping 64 can shed some light on this.
kendosperling
I think you got me wrong. There will be a problem if you change for example only the left side of one cable and leave the right one. If you reverse the polarity on left and right than there will be no problem.Its going to cost me about $70 usd to get it redone by Triton (and mailing time). So I'd want to avoid.
Bimbleton
- Oct 12, 2013
How long did 64 Audio take to make and deliver your A12T’s?
KuroKitsu
Ah perfect then, that was the only situation in which the phase tests failed.I think you got me wrong. There will be a problem if you change for example only the left side of one cable and leave the right one. If you reverse the polarity on left and right than there will be no problem.
Total: 16 (members: 0, guests: 16)
