BananaOoyoo
One of my local stores does that as well - they’ll actually 3D print you a copy beforehand so you can take them home and try them for a bit to make sure that the IEMs will fit well.
I found the 18t "overly clear". It is indeed a very analytical iem. It's bass is slightly punchier than the 12t. But I found myself not being able to listen for it for too long and really had to turn the volume down. Quite a fatiguing iem.
IMO, it’s really hard to base the CIEM version of the same model because of the difference between the seal, eartips and possibly shell enclosure differences. Thus the A12T and A18T might sound dramatically different than their universal versions
Today I managed to audition several iems.
Custom Art Fibae 7
64 12t
64 18t
FIR M5
Lime Ears Aether R
QDC Anole VX
My personal ranking of the above.
U12T, Anole VX, Aether R, fibae 7, 18t, M5
I was quite surprised that I liked the U12T the most, considering I've read some reviews and descriptions that it is a bright iem. I personally found it very resolving with good clarity, with smooth highs that are far from sibilant. I found it better tonally than the rest of the iems I tried. It had good amount of distinct and punchy bass which did not overpower or bleed into the mids.
The anole VX had the best bass of all. Very visceral and textured. Super impactful bass. The highs are more extended and it seems brighter than the 12t, but not as bad as 18t. Presentation is more forward than 12t. I tried flicking the 3 switches. I preferred all the switches off; bass switch on made it sound a bit muddy and too thick. Mids switch made the songs I listened to sound funny and too unfamiliar. Highs switch on was really unbearable for me. Anole VX soundstage > U12t
Aether R had a good amount of bass but didn't seem precise and there was a lack of slam compared to 12t and anole VX. It had the smoothest highs of the lot and was the least fatiguing. The mids were luscious and vocals sound clear. Flicking the bass switch on made it sound too muddy.
Fibae 7 seemed the most easy going of the lot. It didn't do anything glaringly wrong but at the same time didn't seem to impress much. If I didn't know better, I would be totally fine and happy owning the fibae 7, but not after having heard the anole/u12t, which are much more impressive iems.
I did not like the FIR M5 at all and actually preferred my shure 846.
I will most likely go back and get a custom made for the U12T. I kept going back and forth between the U12T and the Anole VX (I must have swapped iems more than 30 times). Although I was very drawn to the bass of the anole vx, the comparatively smoother highs of the U12T won me over. I found I could raise the volume higher with the u12t and that really compensated for the bass (over the anole).
...the comparatively smoother highs of the U12T won me over.
The A18t does in fact sound much smoother and slightly bassier than the U18t. I've also heard U12t and was extremely impressed with it as well, however my A18t is more to my preference. Don't discount the difference cables can make in fine tuning, I can recommend both PW and Han Sound cables.
The A18t does in fact sound much smoother and slightly bassier than the U18t. I've also heard U12t and was extremely impressed with it as well, however my A18t is more to my preference. Don't discount the difference cables can make in fine tuning, I can recommend both PW and Han Sound cables. Also with either custom version you can use the 3 Fir Audio modules for a total of 5 possible tuning options (6 if you include the carrot) for the A12t/18t. Either monitor is top shelf, but for me it's A18t. Look forward to hearing the Fir Audio stuff.
PW 1950
More detail, better spatial cues, more energy and liveliness, better bass from my experience.
Yes it's subtle...but it's there and if you can hear the difference and appreciate it, you're in for a treat.
All the cable conversations and significance of listening to what others say is pointless. Try it for yourself and see what you hear.
If you hear what I hear, you'll be amazed.
Thanks, Joshua. Do these companies allow for home auditions?
