May 22, 2024 at 2:03 AM Post #23,626 of 25,219
I was just able to purchase a U12t second hand! I've noticed that the 64 Audio IEMs look to have rather unique nozzles. What eartips are you all using with the U12t or other 64 Audio IEMs? I use the Tangzu Tang Sancai tips with almost all my IEMs, but I'm not sure they'll work out well for the U12t.
Symbio F and Eletech Baroque with U12t and U18t
Pentacon Coreir with Fourte and Trio
May 22, 2024 at 2:08 AM Post #23,627 of 25,219
I've never heard of those Baroque tips before, but they look seriously fancy. I know a lot of people like the Symbio F, but I'm not a fan of foams.
Have you done a bunch of tip rolling on the 64 Audio IEMs before grounding on those options?
May 22, 2024 at 4:27 AM Post #23,628 of 25,219
Yes of course! Have bags of tips... various types of spin-fit, JVC including Spiral Dot, all types of Symbio, ePro, Divinus Velvet, Alo/CFA, Final, Comply, Dunu, Azla, Zotech and others whose brand I cannot even remember anymore.
I spent months A/Bing and, as a reference, I like deep insert with ultra wide bore, or with the edge of the tip ending at the edge of the nozzle (for all with the exception of the Pentacon that are actually extending the nozzle closer to my ear drum for Fourte, Trio and Supermoon).
For some IEMs models (my end games - e.g. U12t), I have two units so that I can A/B in the most effective manner.
May 22, 2024 at 4:30 AM Post #23,629 of 25,219
Yes have bags of tips... various types of spin-fit, JVC including Spiral Dot, all types of Symbio, ePro, Divinus Velvet, Alo/CFA, Final, Comply, Dunu, Azla, Zotech and others whose brand I cannot even remember anymore.
That's a whole lot of eartips. I'll have to check the ones you've mentioned out if you've tested out that many.
Correct me if I'm wrong, but are you saying you have two U12t's??
May 22, 2024 at 4:36 AM Post #23,630 of 25,219
I have spent a fortune in tips and, every time I see a new model I just get it to try it out.
yes I have two U12ts. (on one of them the Eletech Baroque have inside the foam from a Symbio W for a better seal)
May 22, 2024 at 4:40 AM Post #23,631 of 25,219
Wow, I feel like I made a decent choice with buying a U12t if someone liked them enough to buy two of them.
May 22, 2024 at 4:45 AM Post #23,632 of 25,219
There are really good ... one of my end game models, ... at least from my perspective.
(please keep in mind that I value high end technicalities, V/U shaped, love the air-ness of 64A's IEMs, + I like the shells to be small and comfortable so to be able to wear them for hours when needed. Others may have their own preferences that differ from mines).
(I tried lot of IEMs too bettign to the point where I was only hovering around some flagships/brands that I knew were close to what I was looking for).
May 22, 2024 at 4:50 AM Post #23,633 of 25,219
I enjoy much of the same and comfort is very important as I have my IEMs in all day for the most part. I'm feeling a lot more confident in my purchase, so thanks! These were by far the most expensive IEM I've bought, so I'm hoping they're awesome.
May 22, 2024 at 5:00 AM Post #23,634 of 25,219
I'm using the ePro EP00 3.7mm on my fourte blanc
May 22, 2024 at 5:02 AM Post #23,635 of 25,219
May 22, 2024 at 5:05 AM Post #23,637 of 25,219
Head-Fiers!
My U12t have been an uncontested top choice for quite a few years by now..
Thanks for the help! I'll have to check back in once the new IEMs arrive!
May 22, 2024 at 5:09 AM Post #23,638 of 25,219
They are REALLY awesome. I think you should be thrilled about your purchase. I bought my pair around 2 years ago, and for me they were and are still the best set out there. This includes demoing many other top iems before and since. They are great and incredibly versatile with different types of music.
It did take me a couple of months to finally find tips that fit me perfectly: https://www.amazon.com/AZLA-SednaEarfit-Standard-Pairs-Size/dp/B0B48P171D/ref=sr_1_6?crid=1N8FZU92ONS7F&dib=eyJ2IjoiMSJ9.bwkERoJlc1wS0Bf6Wg4a8Z7F_XayPBAo43NFlvT-JH5ckTQPOHw5pkUkPMVjD_ec4LZpW3sifJyEmy_OHzWTskO4zh9EHZU_aU7T6nlXZA7I6ZgTkemaq67gElTEjYA162ZEkOqb0LD30ZSXeb_E9-wnsyAhxwwguMcZppaNxAEo0LnZGPtkgONqDwzsPpe6.NWTJh5Xw_jjsQmqH7tdjOqmsfXEvXoWxskPTrTwagg0&dib_tag=se&keywords=sedna+max&qid=1716368723&sprefix=sedna+max+,aps,293&sr=8-6&th=1
I use the ML size in one ear and L in the other. I tried many, many different types and brands of tips, I couldn't get a good, snug fit in both ears until I used these.
A big advantage is that there's a screen inside, so the inside of your U12t stays very clean.
May 22, 2024 at 5:14 AM Post #23,639 of 25,219
Good to hear! Thanks for the recommendation on the eartips! I have a small list going here now
May 22, 2024 at 5:16 AM Post #23,640 of 25,219
Thanks, I'll check these out! I see the Final Audio ones recommended often, so I should probably give them a shot.
No worries.
The Final Type Es are smallish/olive shape (bit like the old Shure olives) so they fit quite deep, whereas the Spinfits are larger/have a larger bore size. So depends on the shape of your earholes as to which will give you a better fit.
