Yup! Here you are:
These are both with the M15 module and matched at 1kHz. Anecdotally, I would agree that the U18S's pinna compensation leans even more relaxed than the U12T's. You can also see the U12T has more lower-treble energy which is part of why I said the U18S comes off as darker in comparison. I'll have to sine-sweep them to confirm more differences in treble, though, as the resonance peak area is finicky.
I'm mostly associating mid-treble with instrument
crash. Unfortunately, I don't know the names of all the instruments I hear, and I'm sure someone else can do a better job of explaining it than me! Someone like
@Deezel177 comes to mind, his explanations are top-tier.
Anyways, the problem with this stuff - and so much in audio - is just how darn subjective it is. Everyone has their own interpretation of what falls under each frequency range. For example, I recently learned that audio engineers consider the upper-midrange to fall under 2kHz, whereas I'd say it goes up to around 4kHz. The latter is more colloquially accepted, but the reality is that much of the female vocal fundamentals
are under 2kHz. When you listen to a sine-sweep at 3-4kHz, you don't think midrange; it's much higher-pitched than that. So really, it's just female vocal upper-harmonics that extend into 4kHz and beyond. You can use this excellent chart for a quick reference, but again, there's lots of overlap and it's pending your own interpretation.
