odessamarin
This is all very inresting point. But..
yaggy in my mesurment indicate shorted pin 1 and 3. - 0,03 Ohm.
While other fully balanced DAC has 9,4 kOhm
The reason why Yggy did like this i don't know. I though XLR connectiom is done to isolate both signals positive and negative. But seem not the case here.
And if its AC scheme as yuo mention so with different frequency resistance will change.. well sound even worse, becouse it will be non linear.
So from my simple usual meaurment (case ground is connected to cold xlr signal) pin 1 and 2 in yggy.
I am trying to understand why has no issue with other DAC i have with balanced connection..
but yggy had this paricular differance in my case. When it connected balanced, its like lower frequencies just truncated and not scale with volume. We all know rthis feeling when on a good gear you easly can go loud and enjoy linear response. But here , mids just saturate everything.
While connected with SE RCA all good. Ordered XLR attenuaters, but have bad feeling it wont help. Something is strange there... kind of upset cant use it balanced. Otherwise would not bother with all this measurment.
May be try to call shiit for any idea what could it be..
