Austin Morrow
All the reviews using Mac sources used a USB-SPDIF converter.
But what if you don't have one. That's the problem. Some don't want to use them, like me.
Truth be told, I don't have a USB to SPDIF convertor and would prefer not to have to buy one. The less things are between my Mac, DAC, Amp and headphones the better. Can a convertor colour the sound in any way, or is it simply just a method of delivering the signal to the DAC in original form?
In any case, can anyone recommend a decent but affordable one? Suppose it can't hurt to have one handy.
Have you tried a SPDIF to Mini cable with your MacBook? There's a chance this could work and save you having to use a converter.
Just a few shots. More to come later
I'm glad to hear it supports Mac OS X natively. I don't like the new connectors at all, the original connectors were very beefy looking.
WIth your Mac do you find that you can still control volume or is it disabled?
Will I normally prefer my DAC to lockout volume control it's not a deal breaker, a USB-S/PDIF converter can do that.
Are you getting full 24/96 out of it?
