The "Lovely Cube" Headphone Amp (Lehmann Black Cube Linear Clone)
May 19, 2014 at 3:46 PM Post #1,156 of 1,624
Now I found a store autemashop.com here in Sweden selling BD139/140-16 (ST) and BC550/560C (ON Semi) at ebay:
http://www.ebay.com/itm/111310652096?_trksid=p2055120.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The prices are really affordable and they will ship to Europe and US.
I just bought 40 pcs BD1xx-16 and 100 pcs BC5x0C.
And I also have to say, when I upgraded my first Lovely Cube with RK27 volume pot, some polystyrenes and "snubbers" (0,1uF caps) to bypass the rectifier diods BYV27, the sound was getting much quiter.
So now I´m just waiting to start building my two new amp´s, just a few things left to get.
May 31, 2014 at 7:04 AM Post #1,157 of 1,624
I have just received the transistors, BC550C and BC560C is On Semi and BD139-16 and BD140-16 is Fairchild (not ST Microelectronics).
But the BD´s do not have any metal survace at the back of them, please see pictures below. Do the Fairchild not have metal surface on their transistors? Will the heat dissipation for the heatsink be equally good?
/ Mikael Markstrom
May 31, 2014 at 12:23 PM Post #1,158 of 1,624
I see that Fairchild warn for counterfeits: http://www.fairchildsemi.com/includes/sharedText/counterfeitPartsPolicyStatement.html
Here are also a picture of some LM337 that I have. May all those be genuine Fairchild, or are any of them maybe counterfeits?
/ Mikael Markström
Jun 5, 2014 at 12:35 PM Post #1,159 of 1,624
Citação:
Postado Originalmente por DeGato /img/forum/go_quote.gif
Não existe o melhor ou o pior. Cada grau de seleção tem a sua finalidade. Geralmente -10 -16 ou B, a seleção C não tem nada em comum com o áudio. Ele vem das fabricantes e descreve apenas limites dentro dos quais um transistor especial de toda a massa terá sua hfe.
Quando se trata de BC5 ** no tampão sua hfe afecta a impedância de entrada do tampão. É importante se você usar OPA que não consegue lidar com carga pesada com um relativamente pequeno de impedância. Neste caso hfe do BC5 ** deve ser bastante elevada. Por outro lado, demasiado elevada hfe tem os seus inconvenientes. Outra coisa importante é hfe diagrama / atual. Dependendo da quantidade de corrente passa através de um transistor ou a sua temperatura a hfe irá variar. No melhor dos casos o desvio de hfe deve ser o menos possível em um determinado intervalo.
Também vale a pena considerar a deriva térmica ea capacidade interna de um bipolar entre seus pinos, se você quiser obter um resultado estável e previsível.
O PCB verde tem layout um pouco diferente no outro lado da moeda. Mas ainda não é o melhor. Eu estou trabalhando em minha própria revisão de um PCB com canais completamente separados com proteção de ouvido e filtros separados, reguladores de tensão, retificadores e para cada canal otimizado para componentes de áudio.
http://www.mightything.com/lc/images/BCLv2_alpha.jpg
Felicidades.
Olá
Esta versão parece interessante,
já tentei essa versão da dupla mono?
joga bem, melhor do que Lehmann?
Jun 5, 2014 at 12:57 PM Post #1,160 of 1,624
  Olá
It measures a bit better. More space and the overall performance is better. Personally, I prefer it over the original one. It also has important protection circuit for headphones. It's important in case if you have expensive or rare headphones :)
Jun 5, 2014 at 1:02 PM Post #1,161 of 1,624
Plastic body is ok in some cases. I've seen genuine parts made like that.
In case if you are not sure about the origin it's better to send an e-mail with some photos to the company which produce those chips.
The same for Fairchild.
/ Mikael Markstrom
Jun 9, 2014 at 7:50 AM Post #1,164 of 1,624
Could put some pictures so we can enjoy?
At the moment I am also building a version identical to the original with PRP resistors. I do not know what this is going but I've read somewhere that these resistors have a cooler and shrill sound!
Jun 28, 2014 at 7:48 AM Post #1,166 of 1,624
The lower economy class: NJM2068 NE5532, OPA2134, OPA2604
Middle class: AD8620, OPA1612, LM741 (never used)
Top class: OPA627, LM4562 or LME49600/ 49720/ 49860, AD8066, OPA2227, THS4032 (my favourite, need´s 100nF cap between pin 4 & 8 for stabilization)
Those are dual OpAmp´s and ready for use directly at the board. If using single ones, such as AD797, you will need 2 of them and a Brown dog adapter. Also have in mind if they are DIL/ DIP or for survace mounting. Surface mounting are more tricky to solder, and you will need an adapter also (if you´re not a solution handy man like me and MacGyver :) see pictures below of some of my mod project´s)
http://tangentsoft.net/audio/opamps.html
It´s also possible to use a discrete OpAmp, such as Burson, John Hardy or Audio GD, but they´re very costy and bulky!
/ Mikael Markstrom
Jun 29, 2014 at 6:26 AM Post #1,167 of 1,624
Edit: Sorry, also the OPA627 is single and will ned an adapter for using 2 IC´s.
Also, have in mind there are some single version OpAmp´s of those I listed, such as: OPA134 (instead for dual OPA2134), AD8610 (AD8620), THS4031 (THS4032) OPA1611 (OPA1612). There is some advantage, such as a bit better channel separation if using two single OpAmp´s, but the cost is a bit higher, it need´s more space at the board and more work to solder.
/ Mikael Markstrom
Sep 14, 2014 at 3:55 AM Post #1,170 of 1,624
I wrote sometime ago about wanting to try to improve the performance of the BCL clone by improving on the power supply.  I've have done a lot of upgrades on my current unit and it really does sound great.  I changed the original input caps from Wima MP-10 to some Mundorf Zn pulls I bought and it seemed to improve the clarity a bit.  The Mundorf caps in the power supply also helped a little.  But the biggest upgrade was my DAC I moved from the ODAC to an Arcam rDac and the improvements were immediate and unmistakable.
Now I'm going to try changing the power supply to a shunt regulated low voltage power supply by Salas at Diyaudio.  It measures very low noise.  I've attached a picture with the different power supplies that it was up against.  I don't have a distortion analyzer so my observations will be subjective but I will give my honest assessment.
