noobDiyAudio
asmuch as I can agree with what you said, the whole thread started as support to somebody who has no or minimal knowledge, and minimal tools. AND no titme or possibly inclination to go take a course and buy tools.
the topology of the amplifier is quite simple.
if you remove the OpAmp, you basicaly have the input signal terminating on the Opamp socket input pins. this then goes Nowhere UNLESS the OpAmp is in the socket and working .
if you feed the same signal on each channel ( rca) you should expect to get the same value on each channel input pin on the socket - and if you don;t then you have a problem in the path to to OpAmp socket input pin.
if you do get the same vaolue , then it is likely that there is a dead opamp channel.
the whole discussion has gone the way it has simply because of the assumption of minimal knowledge of electronics and no measurement instruments apart from universal meter - tape and gum so to speak. I still think eliminating cold solder or even something as trivial as short under the board across the positive and negative inputs on one channel is simple enough to do .
But yes, a course and instruments would be great if the interest is there - otherwise it will be much cheaper to simply go to the seller and get a replacement or refund -with the risk that the same problem may happen again.
Hi thanks for the help, I've asked the seller to send me a replacement.
