Hi ClieOS. I just spontaneously ordered the BTR5. Of course, it's possible that I didn't do the appropriate research before ordering lol (wouldn't be the first time!).
I've was using the ES100 (before it broke), and more recently the Ubtr to get me by (I couldn't wait for the 5K any longer).
Although I do have some balanced headphones and earbuds, most are single sided, and I do tend to listen quite a lot to my single sided gear, so what you said above has me wondering!
To get a feel for how the BTR5 sounds single sided, how would you say it compares to the ES100 single sided?
Reading through your initial posts again, you've got me intrigued with the HiBy W3. How does the BTR5 single sided sound compared to it?
Thanks!
p.s. my apologies if you have answered these questions in here already.
BTR5's 3.5mm is about the same level as W3 / UP2. I'll say ES100's 3.5mm is slightly better, noticeable (especially in 2X current mode) but not in any night and day difference. Just to be clear - BTR5's 3.5mm doesn't sound bad, but it is not on the same level as its 2.5mm and more comparable to those in the sub-$100 region - which of course is somewhat of a disappointment when it is supposed to be the best (and certainly the most expensive at its launch) of all the BT adapter out there.
