Can some of you guys perhaps help me out?
It has finally come to it: Had to upgrade my phone, of course no headphone jack.
Had the BTR5 on my list, but now came across a video on Youtube basically saying it's sounding bad and the UP4 is the superior device.
Now I don't know how credible this guy is since he might be a click bait contrarian in order to get some views, but the release of the BTR3K didn't help in making a choice either.
Here in Europe I'd pay around 63€ for the BTR3K and 90€ for the BTR5. Shanling is out of contention since they're more expensive to import.
Money isn't really the issue, but I'll be mainly using the 3.5 Jack since I don't own balanced cables for my main IEMs.
I'll also be using the device as a DAC when I'm on travels since my laptop has a really bad sound output (thanks, Lenovo).
What kind of device would you say makes more sense to purchase? Since I saw ClieOS BTR3K write up, I think this might be the right device for me, but the DAC in the BTR5 sounds more appealing (on paper at least).
If you need the extra power and better USB DAC function (*namely for Hi-res and DSD), then BTR5 makes more sense. If you prefer portability / simplicity and a higher value factor, then BTR3K makes better sense.
UP4 has its own issues, which I have discussed. It won't be a completely bad buy if it is the only BT adapter of its kind at its price range. The problem is that there are noticeably better options for the same (or less) money that have none of those issues. The important point about any review is of course that you have no idea the quality of the reviewer and thus you don't know how reliable and relatable his/her particular review is going to be after you factor in personal taste / bias. This is where measurement can be helpful on making sure that the gear in question will at least objectively be issue-free on the basics..
