The Hi-Fi + Hi-Res Audiophiles' Bluetooth Headphone Adapter Thread - [17.Oct.21] iFi GO Blu impression added
Feb 22, 2020 at 1:33 PM Post #451 of 1,312
Feb 22, 2020 at 3:54 PM Post #452 of 1,312
Feb 22, 2020 at 5:41 PM Post #453 of 1,312
Thanks for the tips, I’m going to try 2 RCA-to-1/4inch cables from the piano to my Schiit Asgard, then connect that to my DX200 which has Bluetooth. Hopefully that does it. Unfortunately the only output from the piano is RCA-to-1/4
Feb 22, 2020 at 9:21 PM Post #454 of 1,312
Don't own a DX200 so I can't say for sure. However, having BT doesn't means it will act as a BT transmitter in the way you wanted.
Feb 22, 2020 at 10:48 PM Post #455 of 1,312
It can connect to Bluetooth headphones, just tested, so if it gets a signal from an amp it may work, will let you know
Feb 23, 2020 at 2:30 AM Post #456 of 1,312
The problem isn't connecting headphone to DX200, but Schiit Asgard or even just the piano to DX200. It will required DX200 having an ADC (Analog-to-Digital Converter) section, which I don't think it does. Basically a TV-to-Bluetooth transmitter will work for you, something like this: https://avantree.com/sg/oasis-plus-bluetooth-transmitter-receiver
Mar 24, 2020 at 5:18 AM Post #458 of 1,312
List updated with FiiO BTR3K
@ClieOS bro i don't know if you could help. I somehow can't pair My AP80 to my Fiio Q5s. Intermitently they do pair if i try multiple times but most of time its a no go. These two devices seem mutually exclusive since they always work with other devices. I beleive as reported on other threads no one has been able to make the AP80 work with the Q5s. Such a shame since i got the Q5s to pair with the AP80 on LDAC. Hope you might have an explanation.
Mar 24, 2020 at 7:33 AM Post #459 of 1,312
I have no experience with the Hidizs to really tell what could be the problem - but it is more likely a BT source issue rather than a BT receiver issue so there could be something wrong inside AP80's OS
Mar 27, 2020 at 2:53 AM Post #461 of 1,312
Mar 27, 2020 at 9:30 PM Post #462 of 1,312
Companion app for Shanling UP2 & UP4 is now available: http://en.shanling.com/article-CompanionApp.html
Tried.
First thing to note is that I can only connect it with UP4, but not UP2 (even though UP2 works just fine). It keeps saying connection time-out. UP4 works fine with the app but it doesn't really add much function except for EQ, which I can't use as I am on LDAC.
Second to note is that the app can't exit normally (*it will stay on the notification area) and require force stop.
Overall a good try, but it need more polishing.
Mar 29, 2020 at 10:50 PM Post #463 of 1,312
Strange that you are having issue with connecting two device, I have both UP2 and UP4 connected on my phone.
Does both of them show up in the app(Under Bluetooth device control tab)? If so, can you try to delete the UP2(swipe left on it) and connect it again?
If you tried fresh install of the app, can be UP2 paired as a first device?
And exiting app, it was already reported to the app team.
Mar 30, 2020 at 9:27 AM Post #464 of 1,312
I figured out why - I accidentally disable UP2's phone call ability in its Bluetooth profile (*I only used it for music so I didn't notice it was disabled) and that's the reason why the app can't detect UP2. Once I have it enabled again, the app connects to it without any problem.
Mar 30, 2020 at 9:50 PM Post #465 of 1,312
Thanks, will keep this in mind if anybody else will have similar problem!
