castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
How do I use a VST wrapper and something like Electri-Q? I don't quite understand how to get the two to worth together..
Also, can anybody input with my question below?
Hello guys, I'm resampling some hi-res flac (88, 96, 176, 192khz - 24bit) to 44.1 or 48khz - 16bit files on foobar. I'm using SOX resampler which I've heard has built-in dither (please confirm).
Question is if SOX resampler plugin does have built-in dither, do I need to apply dither at the file output setting as well (pic below) or is that redundant and not necessary? If the latter, how does it affect sound quality?
you install VST 2.4 adapter in foobar's components tab( in file->preferences->components)
you install any VST(like electriQ) in the VST plug in tab (should be right under the component one in preferences).
you need to restart foobar so that it will load the added stuff, then go to the DSP manager tab (under playback) and move electriQ to the left to use it. at that point electriQ should show up in foobar under view->DSP along with any other DSP you have added to the left in preferences with the DSP manager.
about SOX, I hoped that someone with actual knowledge would show up but I guess I'm all you've got, which isn't much. the SOX plugin for foobar is a resampler and doesn't care about bit depth and so doesn't care about dither. with SOX ( the real deal outside of foobar) and advanced commands you can specify a all lot of things, including bit depth and dither. but I don't think that applies to the default sox plugin for foobar which really is a basic resampler(or maybe I missed something?).
now if you convert to a lower bit depth, IMO dither is always welcome. the circled option on your screenshot is applied at the end after all the possible DSPs you included to your conversion.
