Hi does the X3II recognize replaygain tags on my files? or do I have to manually level the volume using a software? thanks!
The FiiO X3 2nd gen (ex X3K, X3II) Thread : 192K/24B, CS4398,Native DSD, USB DAC with LO and inline remote
- Thread starter viperxp
oldschool
- Aug 10, 2008
A few questions from me too:
- is the maximum volume of the units sold in Europe limited in any way? (e.g. a la iPhone, iPad..)
- does the software recognize pre-emphasis flags (PE flag) in the .cue sheets and apply the needed deemphasis?
- does the software support .cue sheets containing multiple source files?
shineonyou
- Jan 9, 2015
Unable to drive akg k612pro.
shineonyou
- Jan 9, 2015
— to make battery life better
— to make player smaller
— because 200 mW is more then enough for almost all headphones
— to make amp better with lower noise
chose whatever you like
But unable to drive k612 pro.
cleg
- Oct 14, 2011
But unable to drive k612 pro.![]()
There are some physical limitations that can't be pushed even by exceptional company like Fiio
ZGant
- Jun 8, 2012
Kind of a stupid question but, when in DAC mode, does x3 II work only as a dac or as a dac+amp? To put it differently, would I be able to plug my earphones to x3 and listen directly from it when connected to a pc?
cleg
- Oct 14, 2011
Yes, you can listen headphones and I bet you'll like it!
If you'll plug into headphone out, you'll got DAC+amp, if you'll plug to line out, it will be DAC only.
ZGant
- Jun 8, 2012
Good to know, thanks!
ph0n6
- Jul 26, 2014
NVM. Wrong pic
dw1narso
- Sep 4, 2008
Just found a picture of the X3 II internal for anyone interested.
Are you sure? I saw WM8740 there instead of CS4398..., this must be the current X3
sandman1990
Absolutely sure this is the old X3
ph0n6
- Jul 26, 2014
False alarm. Sorry about that
. Anw I will be receiving an X3 II (or X3k as they say in the box) for testing, I'll post my impression with picture soon
jenia1
- Oct 11, 2008
i lold
- Jan 29, 2010
The DAC driver is working fine anyway, I like
- Jan 30, 2011
What are your thoughts a few weeks in Ultra?
Total: 15 (members: 0, guests: 15)
