cireyay
- Oct 9, 2014
Do i still have to use a dac with this. Sorry im a noob to this
If you own a higher level dac than that which is already inside the X3ii, then you should use it. Otherwise there is no need for an external dac.
I don't think that's the question he meant.
Please correct me if i'm wrong, dylanmcbean0819, I believe you are asking do you need to use an extra DAC to use with the X3ii. The answer is no. The X3ii like all DAPs(Digital audio player) or PMPs(Portable music player) have an DAC and Amp built in so you are good to use it independently without needing to connect it to a separate DAC.
