Ting Tiew Yik
- Dec 13, 2015
Joe, I wish I could get that to work. I purchased a ribbon cable microSD to SD adapter; but was unable to get that to work. Have you found any brands of those that do work as you described?
Hey guys, Checking in this thread after a long time.
The Fiio players have this annoying issue where they list songs by the file name and not the title (irrespective of what you select). It can be a huge pain where some tracks in albums are not listed in the correct order.
Is there any current fix/in the pipeline for this?
Thanks.
That's all I've ever seen suggested. All the X series players have a lag. I guess I'm just used to it because it has never bothered me with my X1 or X3II. The lag doesn't affect playback, just going through the menus in my experience. You could reduce the amount of files too, but I doubt anyone wants to do that. You're pretty limited as to getting rid of it so you either live with it or try what I and others have suggested. Sorry, but that's pretty much it.
i guess i didn't explain clearly.The menu is very smooth.Is the playback lagging which bother me
What you select changes what you see on the now playing screen. In the media browser it wil show the file name. I use MP3tag to rename my files to track number title. Easier to see in the browser that way.
I don't know of any requests for changing this or that it is on Fiio's to do list.
I've not heard of this in the X3II. I know the xduuo X3 has the playback lag issue. Are you sure you're in the right forum? If you are referring to the X3II then I would contact FiiO because that's not normal. If you're talking about the xduuo X3, I would refer you to that discussion, or to contact xduuo.
some one told me that it might be the problem of memory card
Have the exact same setup and it blows my mind how good it is! Enjoy
quick question before i buy one of these.
when it is operating as USB DAC, do i then need to chain it to a separate headphone amp? or can i listen straight from the X3?
oh and also does the unit charge when it is in USB DAC mode?
