originalsnuffy
Kind of wondering if the x3 gen one and gen two units are going to see some firmware loving anytime soon.
OOOOOOOOH, that is so exciting! It's going to use dual Sabre ES9018 chips, correct? And will have wi-fi access and a higher-res screen and stuff? At least that's what I think I remember reading before. Honestly that's a bit unnecessary for me though, I have no desire for wifi in my music player, so I kind of wish it wasn't going to have that. . .I have a feeling that if it didn't have the wi-fi and such an incredibly nice display for a DAP, you guys would be able to make it a bit cheaper
Yeah it's going to be waaay more expensive than the X3ii, but I might just HAVE to upgrade to it somedayIt sounds like it'll be such a nice device.
Dude shhhh lol you no give ideas xD, wi-fi may not be needed but at least we can use tidal properly.All so for the display size I think the quality aspect is a good thing, they're about creating well built products. I think the price was 1k or something which really isn't expensive at all. It is very cheap considering the specifications, I was looking at A&K for awhile for a next big upgrade but now price/spec wise the X7 blows it out of the water. My only question would be how DSD is decoded, esp since they're going to support the newer high capacity sd cards we can store more high-res files.
Other than that if you don't need the features meet em' half way with x5II, but the thing there is from my observations is that is more detailed prone and X3II is smoother so is more of personal choice. Then the x7 is A. cause you can or B. Cause you believe those features are an asset not a burden .... Personally I would have bought X5II instead if I knew that then. Any ways super excited to see what comes after the X7 and yes obviously the II but I mean for third gen. Was the X1 Phased out now? Will X3 be phased out? Will only X5 be third gen? How about the X9 will it be able to play 64 bit media, and do the moon walk for us?
Sorry, this is misinformation. The X7 will use a single desktop version ESS9018 32 DAC with eight channels built in (2x superior to the portable 2ch K2M version in a dual configuration).
The chip handles DSD natively and I'm sure FiiO will implement it well. They are working very hard to make sure this is a SOLID Android based player, and for only $699 USD.
With that said, this is an X3ii thread so if you guys want to discuss the X7, or get correct info about the device you can always head over to the X7 thread.![]()
One bug I found, if you leave a song paused for like +10 minutes, and then come back and unpause, there's a buzzing sound and the X3 won't react at all, until you pull out the headphones, and then it willl work again.
Hmmmm. . .neer once had that issue with mine. . .strange! Maybe there's some defective wiring in yours, which would stink. . .you could always write to Fiio about it and see what they say, I hear they have pretty good customer service.
Would stink indeed, hope there's nothing wrong with my x3. Sent them an email.
I am seeking a simple solution to attenuate the line-out level without degrading the signal (or as little as poss).
I have the FIIO X3ii and find the Line out sound's quite noticeably clearer, less "muddy", than the variable out. I got an E12 to try and make use of the lineout but it's still muddying the sound.
I can enjoy the lineout when using it as a DAC, via pc, as I can attenuate using Foobar volume control, of course.
I would like to find a simple solution to be able to use the line out on the go, but not via an amp, just to attenuate the output with minimal circuitry.
Any ideas?
Line outs are designed to drive line inputs, which are typically 10k-ohm (or higher) loads. You risk overloading the line out circuitry or even effectively shorting it if you use a load with low enough impedance. The "minimal circuitry" you are looking for is the amplifier. You can try making your own if you have the time, equipment, and skills. If you're driving low-impedance, current-hungry loads, you need a current amplifier. Any decent consumer amplifier would have both current- and voltage-amplifying stages.
What headphones are you using with the X3?
