hakushondaimao
hi all, i'm seeking some advice...
i've been following the development and release of the x3 since it was announced, and i've considered buying it. i've had some gaps in my audio hardware and i've been getting by with an ipod touch for on-the-go and mobile listening. while i have no doubt about the audio improvements the x3 has over the touch, i love the user interface of the apple touchscreen device, its sleek profile, and its easy interplay with itunes (where i keep my music).
i am not a 'power user' - no playlists, mixes, etc... i simply like to drag and drop whole albums, and listen to in entirety.
for those coming from an idevices (especially the touch/phone), any regrets with the x3 (or x1)?
with the x3, is it as simple as going into itunes library (via finder) and dragging the album folder over to the x3, which i assume will appear like an external drive on the desktop?
any other pro/cons coming from an itouch/phone?
(basically, i either keep the touch and get a dac/amp - like an e17k - that i can also use for my laptop, or i ditch the touch and get an x3, which can be a dap and a dac for my laptop).
THANKS!!!!
X3ii (and previously X3i) user. Convert from iDevices, and not looking back. No regrets. Better SQ. Freed from iTunes. No fighting with disk space issues and whether to delete music or delete apps. It's just music, with no distractions. X3ii is simple and relatively intuitive. Stick in a Micro SD card. Format it with the device. Plug it into your PC/Mac. It shows up as an external drive. Drag your iTunes Music folder onto the drive. Wait. Wait some more. Loaded? If you're an album-listener, use folder browsing, and find and play albums. Easy. Enjoy.
