Anyone here have X1's skin template? I want to try create my own design for my X1.
How about to measured size of bonus skin?
There's no template. You just unpack the firmware and modify the existing themes. It's all pretty straightforward and simpler than creating a Rockbox theme as you can't move stuff around too much.
If you're wondering how to unpack the firmware check clee290's signature 2-3 pages up.
I think he's talking about a template for the stickers (skin)
Does anyone know if the X1 supports .M4A playback?
My first port theme X3 II (getting started)
I could not change the font color in the player. Could anyone help me?
I want to make orange, just like the X3 II
Great job so far! In the Theme folder, there is a config.ini file. You can change the font color there. The player uses hex codes to control the font, so when you see something set to FFFFFF, it means the text will be white. So if you want to change it to orange, you'll need to find the hex code for the orange you want then change whatever you want to orange.
My fiio wouldnt turn on and i used a pin to press the reset and it started to work should i be worry about it breaking in the future?
Just received my FiiO X1. Pairs very well with the IM70. One thing I'm wondering about is the SD Card slot. Is the SD card suppose to click in place? Mine keeps popping right out making this DAP unusuable unless I hold my thumb over the slot.
