Reading reviews, I appear to have gotten one of the X1s from one of the bad batches. The ones with the poor scroll wheels (skipping, unregistered rotations). My purchase was back in December so I don't think a return is possible. Are there any fixes out there?
The FiiO X1 Discussion and Help and Support Thread |192K/24B|100mW | LO | inline remote
- Thread starter JamesFiiO
- Jan 30, 2011
PM Joe - and see if anything can be done.
naldsais
- Dec 12, 2014
James, i just want to ask if the stickers that came with the X1. Would that leave any markings if just in case i want to remove it?
kamoteFX
- Sep 10, 2013
me too has poor scroll wheels and play button, i need to press again the play button just to play a track.
castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
if we had an answer for you we would have answered the first 3 times you asked.
as for james, under each of his posts you can read:
Thanks for your support to FiiO ! Now I can't reply all the PM by myself because the business become bigger and bigger. so please send email to
market@fiio.net if you have any business issues , anything about reviews and where to buy.
support@fiio.net if you have any question...
how about getting out of the broken record situation, and just do what is suggested?
Davidson Braga
- Dec 3, 2014
Man, my unit X1 I realize that the wheel it is a bit soft, do not know. There one time or another, to roll, is not recognized.
Does my unit is the first batch? My unit is on the Gold color, purchased in December.
kamoteFX
- Sep 10, 2013
same here, my gold x1 has problem with the play button and scroll, i bought mine last december.
Sent from Encrypted Transmission by KFX
- Jan 21, 2015
How to u play 192k/24b songs? I have some Flax songs playing at either 44.1k/16b or 44.1k/24b or 48k/14b or 48k/24b. Anyone knows how to get it to play at 192k/24b? Or is it meant to be lime this?
Davidson Braga
- Dec 3, 2014
Citação:
Eu honestamente não acho que isso é um problema. Meu botão Play é padrão aqui, apenas o botão de rolagem que é, por vezes, salta para cima ou de outra. Eu acredito que isso seja uma característica do próprio dispositivo.
Postado Originalmente por kamoteFX /img/forum/go_quote.gif
mesmo aqui, meu x1 ouro tem problema com o botão play e de rolagem, eu comprei o meu último dezembro. Enviado de transmissão encriptada por KFX
dragon2knight
Account disabled by request.
- Feb 21, 2011
No it doesn't. I have had them all on for quite some time now and they remove cleanly. Even if it didn't do so, a dab of Goo Gone will remove anything left behind easily enough with no damage to your X1.
semaj8james
- Mar 22, 2013
Does anyone know how the SQ compares to the X3? My X3 just got stolen and I'm looking for almost only sound quality.
SallymaeHogsby
- Mar 25, 2014
I prefer my X3 for classical and other acoustic music. For rock, pop, and other amplified music, the X3 and X1 sound quite similar to me.
semaj8james
- Mar 22, 2013
Thank you! Also, am I able to simultaneously use line out and headphone out on the X1 like I could with the X3
- Jan 30, 2011
Not at the same time - they both share a single 3.5mm output port.
semaj8james
- Mar 22, 2013
Ahh so the line out and headphone out are in the same jack?
How does the TI DAC in the X1 compare to the Wolfson one in the X3?
