I have a question about making playlists and transferring them to the player. There are some instructions on the Fiio site about creating playlists using Foobar which I have done and copied it to the SD card. I then expected to go into the playlists section on the player and see it named there with all the tracks. All I can do is go into Browse Files, I see the playlist there but when I select it then try to play a track it says file not found. I like to have playlists, preferably named but it's not working how I expect it to.
I have tried to register for the forums to ask someone help but it says I am still not registered so I can't. Does anyone know if this is the only way to do it or am I missing something out. James, if you see this you might be able to advise me.
