clee290
- Oct 29, 2009
Awesome thanks. Can anyone recommend a good way to format the card (FAT32 I believe?) on Windows XP? Whenever I try yo format anything, it only goes up to something like 2.81GB
As olddude said, you can format it using the X1. I personally used another software (can't remember the name right now) because when my card was formatted with the X1, my other player couldn't detect the card. Once I formatted it with the other software, it detected it and I can now use the same card in both players
But yea, if you just need it for your X1, you can just format it from the device.
