Music Alchemist
Pokémon trainer of headphones
- Dec 17, 2013
STAX...it's in your anime.
At least a few of you were waiting for my impressions of the Focal Elear with the Mojo.
I am taking endless notes that may evolve into a full review, but this is the gist of it:
- It is my new favorite headphone.
- Tonal balance is tuned like the HD 650. (Click here and here.)
- Technical performance is akin to the HD 800. It seems to have even better resolution and imaging. Picks up all the details the HD 800 does, but sounds far more natural and musical. Soundstage is a bit narrower, but more three-dimensional.
- Not as neutral or transparent as the STAX SR-207.
- EQ makes it pretty neutral. Just tone down the bass, bring up 3-8 kHz, and cut the peak around 9 kHz.
- With softer recordings, it's the most gorgeous thing I have ever heard. ️
- Has good microdynamic snap...
- ...but lacks macrodynamic power. When I want strong impact and dynamics for more energetic music (like metal and electronic), I easily prefer the Yamaha HPH-MT220.
- Comfortable for its size and weight, but the lightweight Koss Porta Pro is many times more comfortable.
- Build quality and aesthetics are superb. (But don't run over it with a tank. This isn't a Chord DAC.
)- The cable is ridiculously long, but probably the sturdiest, nicest stock cable I've seen.
Hey guys and gals! Only been a member for a bit more than a week now, but I've heard great things in regards to Stax headphones in the past. I myself have a pair of Sennheiser HD800 ( used to have HD650 and HD580, also HD598 but I'd really love to try out electrostatic headphones at some point ).
Is anyone able to recommend an entry level option that I could try out? There's a Stax dealer in my city, and they have quite a few models available for a demo at the store, along with the respective amps.
What sort of amp did you use to power those?
I wanna get the srs-3100 system from a seller off of ebay, but I've never bought something directly from overseas before. It would be imported from japan of course. Does anyone have experience buying a stax system off of ebay and can tell me how much I might be paying for import tax/duties/etc.? Please.
I've never been hit with import duties in the US. The thing you need to consider is a stepdown transformer though, since the modern japanese units are all 100V and very difficult to alter.
Thanks for the reply! I know about the unit being 100v, I also read from some posts that using a 12v power brick would be sufficient (correct me if this is untrue).
About the cheapest I've seen on eBay for the SRS-3100 is US$710. By the time you buy a stepdown transformer, you'll probably be at $740-750.
Given that you can buy the system from staxusa.com for $790 shipped including the correct power supply, I would buy direct and avoid the potential overseas hassles. I'm not sure it's worth trying to save $40-50.
