Spirulina780
- Jan 19, 2016
Too bad the prices on SRS-2170 have increased so much since the release of the SRS-3100
As a newbie Stax owner, what kind of extra care should I be taking? Is it just temperature (0-35 C), humidity (<90%), shock (don't drop it), and dust (cover it when not using)? Anything I'm missing? like surge protection?
I'm no electrician, but couldn't hurt, I'd think? Might function as a sort of crude overcurrent suppressor? *shrug*
No, you should not be worried by this. In fact, you'd better not connect it if you have grounded it via the power cord/outlet. You should only have one connection to ground in your entire system, or else you may get grounding problems such as humming, buzzing or computer static affecting the audio signal.
The ground terminal on the back is very useful, as you said in Japan, but also in Europe, where not all power outlets are grounded. Furthermore, in case of grounding problems, it is useful to lift the ground on all other connected devices in the audio chain, and ground the entire system at one point only using the terminal on the Stax amp.
To name a further example, if you were to buy an entire system (amp, cd player, tuner, etc) from one of the bigger manufacturers, you will often see that only the amp has a grounded power cord, and the other devices have not. This is to ensure the customers do not get grounding problems.
Weird thing is, I never experienced the infamous STAX fart with the SR-207.
Perhaps it's due to the shape and size of my head...
I"m selling my mint set for what I paid... $550
http://www.head-fi.org/t/815069/stax-2170
Ok. Can we stop plugging our sales now. One newbie is excusable.
