ericj
- Aug 2, 2005
Thanks for your reply. I totally get that part. I was hoping for any recommendations on models. I really don't know too much about which ones are good or bad... Any recommendations on specific speaker amp models to look for?
Transformer boxes for electrostatic headphones need very little power.
Somewhere on audiokarma.org in the vintage solid state forum there is a thread about the best low-wattage amps. It might be worth digging up.
From personal experience i can recommend any of the small Rotel amps as well as vintage Kyocera. Many people like old Yamaha "Natural Sound" amps.
But yeah, small T-Amps work too. The only qualm is that they are designed for a 4-ohm load, and the transformer boxes are 8-ohm.
Seems more likely to me that the srd-7 will be the compromised part rather than your amp of choice, though I can imagine that some amp designs with negative feedback might not like the srd-7 as load (just speculation).
Pretty much anything will drive the SRD-7. It's a pair of transformers that are behind some resistors, and the grounds do not meet. The transformers themselves have an impedance around 1 ohm, iirc.
fwiw the old koss transformer boxes have a common ground at their input, which makes them incompatible with many amps. Stax boxes don't have that problem.
