JWolf
- May 3, 2005
I would like to suggest that all the missing photos in this thread be posted again. It would make this thread that much better.
I don't get this one....the "View All" picture gallery is not good enough?
Cheers
. Not going to happen; this thread goes back 8 years. WYSIWYG is the rule, and that's ok.people will post links or embed pictures that are hosted elsewhere, places where they might get deleted. For example: Go to post #13 and you'll see this:
It wouldn't be a problem if everyone that posted pictures uploaded directly to head-fi.
Does anyone have any designs or projects they made for 2 or more headphones? I am looking for something somewhat simple to hold both my ATH M50X's and my soon to come SHP9500's. I am looking for something freestanding so I can put it on the same shelf as most of my stereo equipment.
I made one out of PVC that supports 2. Just a couple of fittings to make a big T, mounted to a board with a dowel and some glue. Simple, but effective.
http://www.head-fi.org/t/249671/the-diy-headphone-stand-thread/1110#post_8291902
Here are a couple doubles I made last year. I put them up on this thread before but have no idea where they'd be in the 233 pages! Anyway, I used some fancy joinery with these which made them tougher but one could do a simpler version with screws and nails without much difficulty.
I think this is the route I am going to take. How exactly did you mount the PVC to the board? Did you cut into the base and then stick the PVC into it? I also like the T piece off the side. I will likely do one of those to hang cables on since I often switch between the two different sized cables on my M50X's.
