BigBadWulf
- Aug 31, 2014
My Sennheiserblade I just bent a Ultraviolettblade, added a magnet and a barbell weight.
I need to build an over head display cabinet with glass doors to fit like 8 pairs of head phones and a bottom drawer for all my iem's. Hopefully I the next couple of weeks my only problem is I usually don't work with wood that much so it could turn out to be bunch of fire wood. I can work with metal but wood is less forgiving.
Don't worry wood is very forgiving. In a pinch it will bend to your will and can always use a hammer if you get really frustrated. In all seriousness though measure 2 to 5 times, cut once. Once you cut there is no going back.
Easter experiment
Found a piece of drift wood by the beach together with an old rusty wire.
Also had two pieces of glass from an old telephone pole laying in the shed, and the rest was just putting them together
Kind of liked the look (didn't find any drift wood to use for base just now, perhaps I'll replace it after I find some)
Easter experiment
Easter experiment
