a_recording
Member of the Trade: Lachlanlikesathing
- Mar 20, 2009
Mupps, when you said the right earcup of your MA900 flopped, did you mean that it flopped so that the earcup flops so that it goes from upper left to lower right relative to the head like:
O \
or does it flop the otherway into the headband assembly like this:
O /
Edit: Just found this post from you:
My pair does this: the left, corded earcup has only slight resistance and just tends to vaguely move with gravity so that the strain relief of the cable points almost straight down and the earcup is only at a small angle. The right earcup flops inwards with a slight 'zipper noise' so that it falls into the headband assembly.
O \
O /
At 4:38 he lets go of the corded earcup and it "flops" to the diagonal position. Just like mine.
Edit: Upon watching further, it seems both of his earcups may return to the diagonal position by default. On my set the uncorded side stays at the angle in which it's tilted, whereas the corded side exhibits the lack of directional fix.
