rtar
- Feb 9, 2011
Memory foam tips on ebay....generic from China, $4 -$6/3pair. Much cheaper than comply. I'm thinking that foam is foam, but who knows? Anyone know if these are any good?
i use these
http://www.ebay.com/itm/Earbud-replacement-noise-cancellation-memory-foam-tips-SIZE-MEDIUM-6-10-30-50pcs-/181347723627?pt=LH_DefaultDomain_0&var=&hash=item2a392aa96b
i think they work pretty good
they don't have the inner plastic core
that the complys have, but you get a good seal
10 bucks for 25 pairs
i use these
I don't know . . . the lack of the rubber core means much of the sound would be dampened by the porous foam the second it leaves the nozzle. I suppose it could be useful for overly bright IEMs, but otherwise I think there are better options out there.
Have they changed their foams to be more flexible over the years? I've found them too stiff and unforgiving when I tried them a few years back.
There are also Monster foam tips which has silicon cores as to not change sound. The mediums will compress down to medium even if they look large but to me are big enough to fit those who normally use large comply. $10 for 6pr from Amazon Prime (free ship w membership):
http://www.amazon.com/Monster-Foam-SuperTips-Replacement-Kits/dp/B003TFEHLG/
These sound pretty good, but how can you tell if the silicon core will fit the earphone speaker stem.....specifically for me, the Fidue A71?
They're made for Monster headphones, so you can use that as a reference. Monster takes Comply 200s, so if the A71 takes comply 200s, it should be compatible with the Monster sleeves.
Are you talking about the Gel version or the Foam version? The foam version is super soft, softer than comply. The gel version I don't find that good because it is too stiff and doesn't compress (although if you get the perfect fit with the gel I think they can work very well, I don't).
