The Deals DISCUSSION Thread (READ THE FIRST POST!!!)
Apr 7, 2020 at 1:20 PM Post #29,956 of 35,319
1 TB Micro SD for $85 for a knock off brand. Looks legit on Amazon so I ordered one, will report back on whether it is a true 1 TB or not:
Edit - fake SD Card
Even if legit, don't know how reliable this is but for use only for storing audio files which is 99% read over the lifetime, it should be ok. It's repeated write/read on the same bits that wear out the silicon.
Apr 7, 2020 at 1:23 PM Post #29,957 of 35,319
https://www.amazon.com/gp/product/B083ZWRK2S
Sorry to say, but 100% fake. It's likely something like a 16gb and 32gb card that is flashed to look like 1tb when a computer reads it.
People get caught on this because you won't fill up to 1tb for a few months (on normal usage, not audio usage) and by then your return window has passed.
EDIT: See this link: https://www.makeuseof.com/tag/how-to-spot-fake-microsd-card/
Also as a PSA, I've read amazon "pools" their inventory of SD cards from multiple sources. So even if you're buying a legit card (let's say Sandisk), you should always run a full test on the card to verify.
Apr 7, 2020 at 1:29 PM Post #29,958 of 35,319
I would not spend $85 on this! No way it is both legit and reliable... so either you'd discover it is NOT really 1TB, or it would die on you in the next few weeks (IMHO).
Apr 7, 2020 at 1:30 PM Post #29,959 of 35,319
I am definitely skeptical but have the utilities and also enough music to fully confirm if this is legit or not. I will just return if this is a scam.
Apr 7, 2020 at 1:50 PM Post #29,961 of 35,319
Well it's definitely looking sketchy then. I thought with the higher price and verified reviews it may be legit. Will know for sure on this Sat.
Apr 7, 2020 at 1:56 PM Post #29,962 of 35,319
Good luck :wink:
Apr 8, 2020 at 2:22 AM Post #29,964 of 35,319
Apr 8, 2020 at 8:35 AM Post #29,967 of 35,319
Same thing happened to me. I haven't received emails from this threads for a while (which was a good thing for my wallet). I unsubscribed then re-subscribed the thread with email notification option, email started working again (bad for the wallet).
This worked for me. My wallet sympathizes...
