A couple little off topic, but I have ordered an AKG K612 and a Cayin C5 from Amazon to use from my iPod classic 160gb.I am confident that the C5 will drive the 612, bypassing the iPod's internal amp using a Fiio L9 LOD. I get good results with my AKG K271 and Topping NX-1 from the iPod via LOD L9, can I expect even better sound from the C5/K612 combination, or am I wasting my money and time because of the iPod's/ LOD L9's limitations ?
Just comparing the impedance of the two phones (55 ohms for K271 vs 120 ohms for K612) and power outputs of NX1 (100 mW @ 32 ohms) and Cayin C5 (800 mW @ 32 ohms), it is expected the K612 will sound better with Cayin C5 compared to NX1. Usually, high impedance headphones are power hungry and scale up and sound better with high power amps, while the low impedance phones do not scale up that much (well, usually, but not always). Also, the Cayin C5 has a very high resolving power and impressive soundstage and imaging, so it should sound quite good (I can't tell how much better compared to NX1 which I haven't heard). You are putting limitation on your sound by relying on the ipod's DAC, but still it should sound good. Also depends on whether you are listening to mp3's or lossless etc.
Also, please refer to this post: post #1604
We need to look into both Impedance and sensitivity in order to understand whether a headphone is demanding in terms of driving and handling power. Higher impedance imply a higher voltage swing is preferred (in most cases), and a lower sensitivity implies more demanding in driving power.
The K612Pro is rated at 120ohm and 101dB while the K271mkII is rated at 55 ohm 104dB, We can almost certain that the K271mkII is a easier load than the K612Pro for sure.
Having said that, I won't rely on specification solely. I have run into too many accidents when I was a number-based man. The only real test is through hoking up the amp and headphone and give it a try with some real music. In my experience, the AKGs 7 series are tough headphones for portable gears. I have tried K701 and K712 with C5, but I haven't tried K612 specifically (and that's why I feel reluctant to offer any opinion in past few days), The K701 and K712Pro shared identical Impedance and sensitivity rating, but I find the C5 can handle the K712Pro satisfactory, but a bit marginal with K701. To provide additional reference point, I would say C5 can handle the HD600/HD650 better then AKG, and if I have to rate the satisfactory level of C5 among these headphones, I would say HD650 = HD600 > K712Pro > K701
But I do agree with sup27606 that given NX1 is rated at 100mW @ 32 ohms and C5 is rated at 800mW @ 32 ohms, I am quite certain that C5 will provide more juice when dealing with demanding headphones and I would put AKG 6 and 7 series into the demanding headphone list.
The iPod might be a bottleneck when compare to the resolution of latest DAC products, but the iPod's/ LOD L9 setup does offer a clean source for the C5, I would expect the improvement will be noticeably obvious. So unless you are planning to replace the K612 with a easier headphones down the road, I do recommend the C5 a good upgrade option for your current setup.
Stay updated on Cayin at their sponsor profile on Head-Fi.
