I received these yesterday and have put them through the paces for a few hours.
I also own or have owned the AirPods Pro 1 & 2, Sennheiser Momentum TW 2 & 3. I also own some higher-end wired IEMs, like the Sennheiser IE900, and I also picked up the Campfire Trifecta. I listen to lot of different genres, so I like equipment that performs well across.
TL;DR - My early thoughts on these is that they are decent, but I'm not sure they're worth it at $250, especially if you already have a pair of recent bluetooth buds. If you're looking at these for your first pair, these may work, but there are a lot of options that I find equally good or better. If you like V-shaped tunes and are willing to use the in-app EQ they are (arguably) better than the AirPods Pro but not as good (arguably) as other true wireless from big audio companies like Sennheiser.
Overall, these are a V-shaped, "energetic" listen. I've listened to my fair share of V-shaped tunes in my day, and these were dark/veiled in the mids and highs, even for me. There is an EQ that helped with this (will come back to that). Tuning aside, the FR performance is just so/so. The mid bass is definitely elevated, but it's not as full or detailed in the sub bass as the competition. I also didn't find the detail of the highs to be any more articulate than the competition, even after upping the highs with EQ a bit. The mids are just OK - not fatiguing, and quickness is OK for the price. Overall, these are not bad per se, but you can get as good or better detail and clarity across the frequency range with the competition at the same price. I find these a bit on the dry side tone wise.
The AirPods Pro 2 have a more balanced overall sound. They are less energetic but have more clarity and detail (if you don't EQ the Orbit). For example, they don't have the elevated bass of the Orbits, but the little sub bass boost that the AirPods do have result in a, more controlled, articulate sub bass and bass region overall. The Sennheiser TW3 have a similar frequency response but simply perform better at it. Sub bass is FAR better on the TW3s, both in terms of volume and cleanliness; the mids are lush and more lifelike, and the highs sparkle a bit more.
The stage and positioning on the Orbit is pretty good to me as well. Width is average, but depth is actually above average and helps give these a good sense of space (something I'm learning may be a Campfire house trait); height is average, and space between the pieces of the mix and positioning performance is also good for a true wireless - better than the AirPods but not the Sennheisers. I would call these moderately intimate. The AirPods Pro 2 take a more relaxed approach to their presentation, putting everything out in front of you a bit (as if you are listening from a few rows back), and the Orbits do that as well, but have better depth and positioning. The Sennheiser TW3s have a more intimate stage that brings everything in close and the sides out wide (as if you are on the stage). Neither of these is wrong, just a matter of listening preference, and the Orbit is between the two.
Where the Orbits really fall short is on the additional feature side. Like a lot in this sub, I put sound quality over all, so I don't necessarily care about other features when I'm buying a new headphone. The Orbits lack of any type of ANC, transparency, auto-pause, etc., and it is a miss at this price point. The connectivity is still a bit buggy, the app is buggy (my left bud always shows 0% charged in the app) even though the app itself is bare bones. You can't customize the touch controls, only turn them off, and the EQ presets have no labels or detail other than number labels, so you either do it by ear, or just make your own custom preset. That's all the app does outside of update firmware. There doesn't seem to be bluetooth multipoint for quick switching between devices, and the app itself only works on my phone, not my iPad. The reason this stuff is a big miss at this price point is because to me, the sound isn't differentiating enough to make up for not having them.
Comfort is good for me personally. Mileage will vary of course, though I found the foam tips to be better for fit (silicon are included as well), and they are stable. I use the smallest size, which I do think is a bit large for a smallest included size, but I can't complain because they do fit, and I could probably do a light workout in them.
It's hard for me to recommend these as a solo daily driver because of the lack of quality of life features PLUS the fact that the sound presentation isn't differentiating enough (to me) to make up for it at this price point. I also think for most, they would require EQ. However, if you can get the EQ to your liking, from a pure sound presentation perspective, these perform well. Everything in this price range has its potential weakness, so it's all about your tastes and preferences
