- Jan 10, 2016
Tempted to acquire the Yatono Ultimate. Right now, I have Naobi LE & Asuha Ref.2. Hope to see more impressions before confirming the order.
I think you can use heat to reshapeI just received an Asuha Ref.2 cable for my JVC FW10000. It's a great cable, which adds some low end, make the sound more coherent, and enhances all technical aspects. Quite a notable upgrade. However, is there a method with the memory wire to make it more malleable around the ear? I find it's difficult to get a decent fit because this part of the cable is overly stiff. Tips? Otherwise, a beat.
OK, thanks - as in a hair dryer or some such?I think you can use heat to reshape
Ok, so just manual adjustment?No need to use heat. It has titanium wire in earhooks like in Yatono cables. Don't afraid to reshape it as you want.
Thanks, that worked, indeed. I just didn't want to "force" it against its will, but the wire indeed can be adjusted.Yes, exactly.
Which do you prefer more? Any big difference between both cable ?Tempted to acquire the Yatono Ultimate. Right now, I have Naobi LE & Asuha Ref.2. Hope to see more impressions before confirming the order.
Asuha for sure. It is superior to Naobi.Which do you prefer more? Any big difference between both cable ?
I’m using sr25 with brise cable. I have the same impression when I demo the M15 the treble is just disappeared.I have borrow Fiio M15 for testing and burning the yatono because the connector is 4.4, which is not fit with my SP2000 and Hugo2.
As previous comment I'm happy with the build quality because of it is not stiff as I thought, my cable is 2nd and the previous owner has light use ( 5 times) then every thing is in the like new condition.
With my testing and and short listening session I would like to give some first impression:
- Sound stage is good, the cable has the ability to extend the top end of the sound stage with lots of high frequency instrumental.
- The background is quite deep dark, which reveal lots of micro and ambiance sound.
- The size of sound stage in the x, y horizontal is kinda one of the best in my collection.
- The ability of control speed, temporal resolution is good, the fluctuation of note, time evenlope is good. Texture and harmonic resolution is good.
However, IMO the cable is still very new and need time to evolve then:
- The sound signature is quite smooth. The vocal resolution is quite opposite to the dream duet. While the Dream Duet reveal more air space the Yatono vocal signature is thicker, more blending and lack of air. The signature is good for some who like it but I like the signature of DD more.
- The smooth in the sound signature make the flute, woodwinnd or trumpet sound kind of lack airy and contrast, adding more mellow tone to the sound. IMO it is more forgive.
- The transient/attach is some how little than other cable, every detail is nice, fuller but the velocity of force, the shaping of piano and the striking is some how kind of reduction. The note is bold and lake of sharpness harmonics in the top frequency.
- The bass line resolution can be better. The start/stop, fluent of organ low register can be better.
When comparing the M15 sound is some kind of laking DR than SP2000, while laking of micro detail and depth. I tried to compare on Fiio M15. If can plug to my SP2000 then my comparison might be better.
Yeah I don't know why cause it real. IMO, firstly it is kind of Dynamic Range compression while it can output very loud, big sound.I’m using sr25 with brise cable. I have the same impression when I demo the M15 the treble is just disappeared.
