I don't yet know of the suggested Audeze EQ fix, can you link me to all the values? Cuz here's the issue I'm at right now after trying things out a little more this morning: these paired with the cipher cable sounds fantastic, easily better than the 3.5mm cable, but it's SO DAMN LOUD. What's wrong with people's hearing? Why is this the lowest volume??? I'm blowing my ears out! I downloaded the app and left the settings as-is in terms of ratio (everything is still just a straight vertical line on the sliders) but moved them all the way over to the left just to make it all quieter.....and it's still too loud. I also would prefer to use the 3.5mm because of how I would like to use these. They're going to be my earphones at work and I listen to music connected to my iPod, but I'd like to be able to easily swap between that, and connecting to the uDAC I've got hooked into the computer for when I watch podcasts or videos during my breaks.
So the ideal is an EQ that would work easily with what I've already got set up on my iPod and can be shut off very easily; that way, I can just use the 3.5mm cable regardless and toggle an EQ. I tend not to be an EQ sorta guy, but I might consider it.
The other option that I'd even be willing to do is swap the cables back and forth depending on if I'm connecting to the computer or my iPod for music, but I don't want to do that without getting something for socket protection. I'd need to have a 0.78mm female to 0.78mm male connector so I can just plug those in to the iSines, then I wouldn't wear out the sockets on the earphones themselves. Basically extension connectors so if they wear out, it's a part I can actually replace, but I don't know of anything like that existing. Know of anything like that? Because if so, I'd be willing to do this sort of solution. Would need to jailbreak my iPod to get a volume step adjustment tweak to allow for fine grain volume control, but the jailbreaking part is fairly easy.
Otherwise, the sound out of the standard cable still isn't bad, just not a stand-out.
EDIT: TL;DR, if someone just has the link to the equivalent EQ values if not using the cipher cable, please and thanks!
